There are Lamb motors of higher amps and more CFM that will also fit in the 2100 series.
I once took a 2 stage Lamb motor out of a Kenmore Whispertone and put it in a 2100 series. I made the horrific mistake of letting the wire harness come loose from the inside of the top half. It took forever for me to reconnect the wires correctly because I didn't have a diagram. One I had it up and running it was a beast! Also, if you ever get a hold of a Rennaissance style canister that you'd like to play with, you can chip away at the plastic around the motor fitting on inside of the bottom half of the body and the 2 stage Lamb will fit snugly in this also. I actually used the cutting blade on my Dremel to do this and then filled in the gap around the motor with spray foam insulation. It was a totally different machine afterwards.
Post# 352739 , Reply# 2   5/24/2016 at 13:03 (2,894 days old) by blknblu(CT)
