Thread Number: 20324
Electrolux Renaissance motor plastic shroud removal |
Post# 227652 , Reply# 1   4/9/2013 at 23:05 (4,005 days old) by SBakerde (Millsboro, DE )   |   | |
There is no trick that I have found just a set of flat heads and a good bit of patients. The rubber shroud has a very snug fit around the base of the fan casing. |
Post# 227919 , Reply# 2   4/11/2013 at 14:30 (4,003 days old) by scvacuumguy (SC)   |   | |
Post# 228906 , Reply# 3   4/18/2013 at 07:49 (3,996 days old) by luxlife (Under a Pecan Tree)   |   | |
Put the motor in a warm place, like a sunny window sill. The rubber will soften when it warms up and then you should be able to gently pry the motor out. |
