Thread Number: 28340
Just Purchased a Royal Metal Vacuum Cleaner |
Post# 316520 , Reply# 1   2/23/2015 at 05:58 (3,350 days old) by FantomFan (Rochester, New York)   |   | |
Post# 316523 , Reply# 2   2/23/2015 at 06:16 (3,350 days old) by rdak (Michigan)   |   | |
Thank you but I can't find anything about Model 1048..........it isn't shown anywhere I have looked to buy parts, etc., should I ever need any. |
Post# 316542 , Reply# 3   2/23/2015 at 12:40 (3,349 days old) by fantomfan (Rochester, New York)   |   | |
They made a TON of these, under many different models. I have the Anniversary Edition from 1992. It's a tank. Bags are readily available, and Kirby belts do fine. I use HEPA Hoover Y bags from envirocare in mine since it's a top fill, not the bottom fill (F & G style). With a little bit of Electric 3-n-1 motor oil (Fill it until you see the oil rising, then add a bit more after a couple of minutes if need be, the motor will last for SEVERAL more years. Royal brushrolls are still available. Good Vac sells a wooden one with white brushroll strips and it isn't that expensive. I'm sure others will chime in. Congrats on one of the best upright vacuum cleaners ever made- Mitchell
Post# 316626 , Reply# 6   2/24/2015 at 12:42 (3,348 days old) by sptyks (Skowhegan, Maine)   |   | |
rdak, You could contact Benjamin Edge mailto:CIIIKirbyMan@comcast.net...">CIIIKirbyMan@comcast.net Ben is very knowledgeable on Royal vacuums. He knows all Royal part#'s and where to get them. |
