Thread Number: 8411
Hoover 425 |
Post# 93502   3/15/2010 at 04:49 (5,155 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
I managed to find time this weekend to do a bit more work on one of my 425s, the one with the badge saying 'rebuilt by Hoover Limited at Perivale'. I'd already freed off a seized brush-roll bearing, regreased the brushroll and tested the motor, which still runs very well. However, the machine was looking a little tatty, needed some attention to straightening of the handle bail, a good clean and polish and a repaint of the black dome and handle parts. Here are some pictures. I still need to find a black furniture guard; I've removed the fitted one, which was virtually falling off and crumbling away, due to going hard. The sprung-in brushes could also do with re-bristling when I get round to it. They are quite tightly stuck in position so I've tapped around a bit with a hammer and punch and put some easing oil in the gaps. Using the machine a few times will help to work them loose I reckon...and I don't want to break them! Stephen |
Post# 93503 , Reply# 1   3/15/2010 at 04:54 (5,155 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 93504 , Reply# 2   3/15/2010 at 05:01 (5,155 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
These were tight in the handle bail and had to be eased slowly to remove. Fortunately, they came out in one piece. It's possible to manage without them with the steel bails, since they can be sprung in slightly by hand..not so sure about the aluminium ones though, such as on the 575. This raises an interesting point; I know that some of the early handle bails are cast and these can't be bent back into shape..or they'll snap..but does this apply to all the aluminium bails? I could do with knowing, since one of my Specials needs it's bail straightening..and it's an aluminium one. Stephen |
Post# 93531 , Reply# 4   3/15/2010 at 15:22 (5,155 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
This particular one is 210 watt. Strangely, it's also the only 425 out of the four which I have, which has the round belt pulley and the round groove in the brushroll; the others have flat belts - I use a Dyson DC01 or early Hoover Turbo belt on them. This one's been retro fitted with a kind of v-belt, which isn't correct...but it's working well at the moment and seems to have the right tension so I've left it. I suppose I should be careful not to use one that's too tight; they often work OK for a while but I've known things to happen, such as brushrolls breaking in two. Of course, if it's not tight enough, the belt just slips and a very tight one will usually snap before it does too much damage. I actually am lucky in having one or two new old stock 425 parts, including flat and round belt pulleys. These are unusual in being recessed where they fit into the fan. However I'm wondering if the one on this machine is actually off a later 450 or 475; it looks more like a 450 pulley. Stephen |
Post# 93693 , Reply# 5   3/16/2010 at 15:43 (5,154 days old) by 1066hoovers ()   |   | |
Wow - the best part of your 425 is the bag - if I'm not mistaken it is the bag from a Model 875. The first Bakelite hood model after the 825 - late 1930s. A rare bag indeed! |
Post# 93878 , Reply# 6   3/18/2010 at 16:23 (5,152 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
You could be right there, though Seamus has/had one, which appears to have a slightly different bag - I think it has blue underlining. That's one of the things that attracted me to the auction; I'd not got that particular bag. One or two collectors have been saying that the 875 was the first bakelite hood model. However, one of my 475s has a bakelite hood/motor cap...and the others have alloy ones. Stephen |
Post# 93884 , Reply# 8   3/18/2010 at 18:14 (5,152 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Jack, you're probably right about the transition from flat belt to round belt occuring during production..only I'm wondering whether mine has been modified since new. This is quite possible, since it's been reconditioned by Hoover in the past and though it's a 210 watt model appears to have the later (round) style pulley...plus the brushroll to go with it. For all I know it could be a 'hybrid' machine with bits and pieces off various 400 series machines! Presumably the 210 watt machine came out before the 240 watt one? As for the bag, if it's not an 875 one, is it some sort of manufacturer's replacement bag..only the others in my possession don't have this particular pattern. There were quite a few different Hoover black bags! Stephen |
Post# 93921 , Reply# 10   3/19/2010 at 09:51 (5,151 days old) by seamusuk (Dover Kent UK)   |   | |
Post# 93926 , Reply# 11   3/19/2010 at 10:49 (5,151 days old) by turbomaster1984 (Ripley, Derbyshire)   |   | |
What I dont get is why the Servicing Information has a picture showing the 160 to have a jet black bag with White stripes. Mine came with this bag, I really ought to get cracking with the restoation of the 5 pre war cleaners I got a few months ago especially the 475 which also has the same bag as Hooverbabys 425. Can anyone confirm this is the 475's correct bag? |
Post# 93931 , Reply# 14   3/19/2010 at 13:41 (5,151 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 93932 , Reply# 15   3/19/2010 at 13:47 (5,151 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 94087 , Reply# 16   3/21/2010 at 09:49 (5,149 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Presumably, this is the one you mean, Walter? I've just temportarily fitted it to one of my 725s for this photoshoot. Eventually I'll probably put in on another machine with the original orange triangular badge. I know that the steel band on this has lost some of its orange paint but that doesn't bother me unduly. I've also borrowed a spring off the other bag; the original has a bracket, which clips onto the bag slide. This one looks good though, even if the furniture guard isn't original. It has the early style of rubber grip with the little diamond shapes in it - they're often perished but this one is OK. I know that there was another earlier more angular type, as used on the 700, which was partly wooden. I only ever had one of those but it had fallen to bits! Stephen |
Post# 94089 , Reply# 17   3/21/2010 at 10:03 (5,149 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Post# 94112 , Reply# 18   3/21/2010 at 13:11 (5,149 days old) by watsonw (Newport, Shropshire, UK)   |   | |
Luuuvvly!!!! |
Post# 94118 , Reply# 19   3/21/2010 at 15:16 (5,149 days old) by kirbyklassic80 ()   |   | |
I've got a hoover 425 special, I have yet to find anyone who has the same vacuum. |
Post# 94131 , Reply# 20   3/21/2010 at 16:17 (5,149 days old) by hooverbaby (Dalton in Furness, UK)   |   | |
Dan, apart from some very early pre-1920 Hoovers, Special was the name normally used to denote machines rebuilt in the U.S Hoover factory at North Canton; thus there were 700 Specials, 541 Specials, 105 Specials etc. I expect that your 425 Special will be a 1932 machine, rebuilt at North Canton, possibly just after WWII. I don't have a 425 Special, though might have seen one listed but I do have at least two 105 specials and at least two 541 Specials Incidentally I know that Hoover, like many other manufacturers, were engaged making special equipment for the War effort and that supply of new machines either ceased or was very limited during WWII. Can anyone here confirm whether Hoover sold any reconditioned machines during the war?..or was work confined only to servicing of customers' existing machines? Stephen |
