Thread Number: 45272
Kirby heritage 2 13” nozzle |
Post# 468920   1/24/2024 at 16:07 by ItsSid (Oshkosh)   |   | |
Just picked up a heritage 2 with a 13 inch nozzle, but it seems the hinges are broken off. Is there anyway I can fix it?
Post# 468930 , Reply# 1   1/24/2024 at 19:35 by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Sid,
You may likely need new hinges; they are part no. 1547. Replacement rivets will be part no. 1545 or 1864. ~Ben This post was last edited 01/24/2024 at 20:41 |
Post# 468931 , Reply# 2   1/24/2024 at 20:22 by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 468997 , Reply# 4   1/26/2024 at 20:53 by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 469003 , Reply# 5   1/27/2024 at 14:40 by Lesinutah (Utah)   |   | |
Bottom plate off a ds 80 should fit. If you could rivet it on it would work. You could use very small metal screws to hold the hinges on.
You could get a regular heritage nozzle for parts. Get hinges and parts off of it. If you use a set tool you could pop out the rivets of the heritage nozzle and reattach on h2 13. You then use needle nose and flatten out the rivets. There's a few ideas. |
