Thread Number: 45253
More suction power??? |
Post# 468759   1/16/2024 at 20:24 by fantomfan57 (Central Texas)   |   | |
Greetings and Happy New Year! Question, which have you found to have stronger suction? A Hoover Portapower or a GE portable vacuum cleaner? |
Post# 468773 , Reply# 2   1/17/2024 at 09:09 by dysonman1 (the county)   |   | |
Post# 468776 , Reply# 3   1/17/2024 at 09:17 by eurekaprince (Montreal, Canada)   |   | |
If you want a really powerful bagged version of the Shark Lift Away, look at the rose-gold Kenmore Intuition Bagged upright…it’s recommended by Consumer Reports and has a nice wide extra large upholstery nozzle with velcro lint-picker strips. It has a “Lift Up” option to take the canister off the motorized carpet nozzle.
Post# 468788 , Reply# 4   1/17/2024 at 14:10 by fantomfan57 (Central Texas)   |   | |
you both. So the Hoover and the Kenmore. I will look into both. Thanks a million! |
Post# 469474 , Reply# 7   2/10/2024 at 18:00 by Durango159 (State College, PA)   |   | |
If you're looking for a lightweight, bagged, powerful canister then the Perfect C105 or similar is where you want to look!
From internet photos, you might confuse the C105 to a Sanitaire/ Eureka Mighty Mite style machine. It is not! The Perfect is larger, not by a ton but it's slightly larger and has a much larger bag that is HEPA. The body is much more durable plastic. The hose has metal ends and it has extreme suction power! It has more powerful suction than most full sized canisters and uprights. You can also find it branded under the Bissell Big Green commercial line. Here is an Amazon link for the Bissell. I recommend checking out local vacuum stores, they should have one to try. Many of the models also offer a socket on the body of the machine to run a power nozzle. www.amazon.com/Bissell-Bi... |
Post# 469547 , Reply# 8   2/12/2024 at 21:43 by fantomfan57 (Central Texas)   |   | |
Rob. I will consider the Bissell. The Commercial Portapower is powerful enough, but it would be great for an even lighter unit. I will take down my GE's and test the power and weight. |
Post# 469637 , Reply# 9   2/15/2024 at 22:26 by Durango159 (State College, PA)   |   | |
You're welcome. The PortaPower is a good machine. But if you want something with a lot more power, larger bag capacity, a wheeled system, the Bissell or Perfect will prove well for you. If you think of it and get a chance, check out or even call your local vac shop to see if they have one in stock to demo.
