Thread Number: 45227
Kirby 1-CR |
Post# 468548   1/8/2024 at 04:21 by ajc31980 (Johnstown PA USA)   |   | |
HI For daily use I will install a Mini emptor and A full length zipper bag. but this idea gives me ability to use the original when I want too and helps preserve the shake out bag. I have Few spare Zipper bags (see pics) not sure what I'll use for sure yet.
The only real issue I've had with machine is the bearings, both front and rear. after about an Hour of run time ( vacuuming the first and second floor) they started to get noisy, and as time went on they became louder. I had set of bearings that I actually bought last year for my DS50, that I never opened because I decided to re-pack the bearings in that machine. So I went trough the struggle of getting the bearing plate screws loose. Actually took the better part of the day soaking them in WD40 and Very much tested my patients ! even vented on FB abut it haha. finally broke them free with my drill. The rest was fairly easy and went as usual. typical bearing replacement. Got the new bearings installed, put everything back together, fired it up and it sounded great! but that was not to last.... after maybe 10 min of run time, they started squealing ! ugh!. so I take it all apart again... take the bearings out, and pop the seal on them to take a look and guess what ? very little grease inside...grrr ( see pics and none leaked out that I could see) so - re-packed packed them and they sound much better with some noise in the rear bearing. I'm afraid it may be damaged now from running on the dry side. The front one is quiet, but feels slitty rough when I turn the shaft by hand. does anyone know of a good source for these bearings other than eBay ? I use to mainly get parts from the EBay seller "Kirby needs" But since Kents Passing the Ebay store is becoming slim pickings. He was always A good guy to get parts from. I'm tempted to get the updated front bearing plate for this machine. It would at least make finding the front bearing easer.
The other odd thing I noticed on this model is this sort of cardboard divider over the motor with foam padding taped together with masking tape. (see pics) kinda odd. the masking tape was coming loose so I re-tapped it with some black tape. I this really something that was done at the factory? also did the machine have the plastic caps on the motor brushes ? Thanks AJ
Post# 468551 , Reply# 1   1/8/2024 at 12:35 by panasonicvac (Northern Utah)   |   | |
4
Post# 468565 , Reply# 3   1/8/2024 at 18:50 by Lesinutah (Utah)   |   | |
Cardboard piece ypu have looks like a mod made by someone after it left the factory.
Kirby changed motor manufacturers mid to late run of the ds80. The motor is a replacemenfrom new manufacturer and then modified for the new 16 inch kirby lines. The bearings in ds50-cr1 I can see spinning quick because there rated for ds80 and they upped the power smashed it in a solid plate instead of a attached bearing plate. It would put more tension and more power with no room for movement. It's a great model. Robs restoration threads I'd suggest you atleast read them. They're very entailed and shows you how to do things without specialty tools. Ya just read his threads. |
Post# 468574 , Reply# 4   1/9/2024 at 00:19 by ajc31980 (Johnstown PA USA)   |   | |
Panasonicvac. hey thanks! it's becoming one of my favorites too! thanks for the video. I've thought about having a full zipper installed on the original bag. not sure if I wan to do that or not. it's defiantly tempting though.
Texaskirbyguy. yes that is the thread I was looking for ! great idea with the Hepa and shake out bag I always like give credit for a good idea. I actually did this with my 519 and DS50as well. I haven't been able to use the shake out bags for about 4 years now. so it was definitely fun trying it out on different models.
the bearings, I'm 100% sure that those are the new bearings I installed. kinda hard to mix up the original bearings with newer style sealed bearings. but do unstained why you asked, I once made similar mistake on non vacuum project in the past. I just placed an order for more bearings from another seller. maybe ill better luck this time around. Ive bought many, many things( including bearings) from Kent over the years and everything was always perfect. this set of bearings were the last available. so maybe they were old left over stock. I read on a FB post that basically his family is just selling off the remainder of stock, so who knows, Maybe they were sitting around for long time. good to know that the cardboard/foam is supposed to be there. I'm guessing that the cardboard is original and someone taped on new foam.
Lesinutah. Thanks for the motor info ! I'm find this model to be very interesting for sure. I'm going to defiantly read through the threads. |
Post# 468935 , Reply# 5   1/24/2024 at 21:32 by ajc31980 (Johnstown PA USA)   |   | |
Just wanted to post a quick update on the CR1 bearings. I ordered new ones for both front and back. And it’s been running/sounding great for the last week or so. Thinking This machine should be good to go for another life time :-). Guess the first set was just my bad luck lol. Ah the sound.. of a happy Kirby !
AJ
Post# 468939 , Reply# 7   1/24/2024 at 22:50 by ajc31980 (Johnstown PA USA)   |   | |
Yes the classic line is definitely nice. I also have a classic III :-)
Kent was the fist eBay seller I ever bought Kirby stuff from back in 2007 . Always very helpful and friendly! He always seemed to have what I needed for older models where others didn’t. I Remember, reading on a Facebook post for the Kirby, USA worldwide group I believe. That he passed away in early 2022 ? I could be wrong though. And I believe that it’s either his son or other family that is still running the eBay store and possibly just selling off the remainder of the stock. I could be wrong on some of the details, though as it was a little while back. I’m sure someone els in here knows better/more accurate details than I do. AJ |
Post# 468967 , Reply# 9   1/25/2024 at 14:53 by Lesinutah (Utah)   |   | |
Oyler passed away sep 23 2022. I met him in person and considered him a great friend. His wife Yolanda is running the store. The last few years of Kent's life she helped him run his ebay store quite a bit. I actually been to Kent's house before and a couple times since.
She signed his business cards the last few years he was alive. The eBay store is now items kirby still sells. I'd love his metal polisher. I actually used it and polished a 500 series nozzle in about 2 minutes. His store is operating and I'm sure he is helping her. I really like the cr1. It's the last kirby Jim Kirby helped developed before he passed. It has an aggressive look to it. |
Post# 468972 , Reply# 10   1/25/2024 at 19:32 by ajc31980 (Johnstown PA USA)   |   | |
Thank you commenting and letting us know what happened and is going on with his store. I tried looking back through posts on the FB Kirby group and couldn’t find the one about Kent and his store.
And agreed. The CR1 does have that aggressive look to it . It’s definitely a beast ! This ones definitely a keeper ! |
Post# 468973 , Reply# 11   1/25/2024 at 19:52 by huskyvacs (Gnaw Bone, Indiana)   |   | |
Funny how everyone that collects Kirbys always has a different Kirby model that eludes them. For me I only keep finding nothing but 1CR's when I want to look for vintage Kirbys lol I have a factory refurbished one, a run into the ground one, and one that's been dressed up as a Classic III. The one I can never seem to find is a DS80. Yours looks like one of the nicer condition ones I have seen, it was taken care of more than most have been. The commutator looks good too, must have been a low hours machine. |
Post# 468979 , Reply# 12   1/25/2024 at 22:06 by ajc31980 (Johnstown PA USA)   |   | |
I know what you mean. The classic 1CR and the Tradition where the ones that where tough finds for me. A Close friend of mine when I was a kid, his parents had a tradition. that was the only one I had ever seen. And I always liked it because it was blue. Locally, I typically see, Heritage 1’s heritage II’s legends, and the G series.
I would always see traditions and 1- CR’s on eBay, but they looked like they were pretty beat up and the price was way too high for the condition. I sort of had a stroke of good luck with eBay over the last couple of months. Back when I was 19 and moving in onto my first apartment I found a DS50 on the curb for trash day. All it needed was belt and brush. A week later I found a DS80 out for trash that just needed a belt . I gave the DS80 to a buddy of mine and he didn’t take very good care of it, and eventually tossed it out, with out telling me. I’ve never seen another one in my area. makes me regret giving it away. Thankfully, I hung onto the DS 50. AJ |
Post# 469080 , Reply# 14   1/30/2024 at 00:05 by ajc31980 (Johnstown PA USA)   |   | |
thank you ! defiantly fun reading reading trough the patent info you shared. I also Have a 519, DS50, Classic III, Tradition, and a Heritage1. They are all my favorites for different reasons. The Heritage 1 is probably the last model made that I really have any true interest in. ( not saying I'd Pass up decent Kirby of any model if one would cross my path) The "Winged tipped " Nozzles are also a favorite for me too. The heritage II models always looks odd to me with out the wings on the nozzles. |
Post# 469110 , Reply# 15   1/30/2024 at 17:50 by Paul (USA)   |   | |
You bet, AJ! Glad you enjoyed it. Keen Kirbying! |
