Thread Number: 44999
Eureka F & G Light Bulb |
Post# 466830   10/16/2023 at 15:10 (213 days old) by Paul (USA)   |   | |
I understand that the 25-watt vacuum cleaner light bulbs are no longer being manufactured. Do the 15-watt ones produce enough illumination?
Post# 466836 , Reply# 1   10/16/2023 at 18:29 (213 days old) by panasonicvac (Northern Utah)   |   | |
They're less wattage, they're cheaper, and they're designed to last longer. I have one on my Sanitaire S677 and it shines just like the old 25 watt bulbs.
www.amazon.com/IAlight-AC... |
Post# 466881 , Reply# 4   10/17/2023 at 21:56 (212 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I actually used to use 25 watt bulbs in my vacuums. Like you, I wasn't satisfied with the brightness of the 15 watt bulbs, especially in some vacuums & powerheads with designs that restrict the light coming out somewhat. The problem I had with them is that they barely lasted more than 2 months before having to change them! And that's a problem I NEVER had using 15 watt bulbs. It's almost as if the vacuum itself burns them out prematurely.
For that reason alone, I use LEDs in my vacuums now. And I can totally see how incandescent appliance bulbs will be obsolete in the next 5 to 10 years, considering LEDs last so much longer & use much less energy. |
