Thread Number: 44973
1930s Hoover Model 300 questions |
Post# 466722 , Reply# 1   10/10/2023 at 17:42 (219 days old) by bikerray (Middle Earth)   |   | |
The 300 used Ball Bearings
Upper bearing 42166 Lower Bearing 42172 The ball bearings take grease Sleeve bearings use oil Agitator Brush Long 82344 Short 82345 If the Agitator is the original then the brush strip will have a screw at the outside end. Take the screw out and move the brush strip toward the center and lift up the end with the screw hole, and take the brush strip out. The 300 was 1935 - 1938 The part numbers are Hoover Numbers |
