Thread Number: 44742
My Cirrus CR-79 Handle is breaking |
Post# 464840   7/26/2023 at 15:10 (295 days old) by mark40511 (Lexington, KY)   |   | |
So this Novemeber I will have had this vacuum 5 years. When I bought it I would told to never pick it up by the handle...so I've been super careful to never do that...but even still, using it today, I noticed the handle kept getting looser and I could see it trying to come apart from side to side as I was pushing pulling it along vacuuming... There are a few phillips screws which I can't tighten..it's like they're all stripped...am I going to have to get a new handle or is there something else I can do?
Post# 464842 , Reply# 1   7/26/2023 at 15:35 (295 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 464845 , Reply# 2   7/26/2023 at 16:57 (295 days old) by panasonicvac (Northern Utah)   |   | |
Post# 464847 , Reply# 3   7/26/2023 at 17:42 (295 days old) by mark40511 (Lexington, KY)   |   | |
Post# 464851 , Reply# 5   7/26/2023 at 21:42 (295 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Could make a suggestion here to a more permanent fix? Sure, you COULD order a new handle assembly. BUT, if the plastic screw posts stripped out, it will likely happen again in 5 years. After all, it is Chinese cheap quality plastic.
What I would do instead is drill out a small hole on the side of the handle where the screw post is. Then go to a hardware store, and get nuts and bolts, and use that to hold the handle halves together. Then you're relying on a metal nut not wearing out, NOT a plastic screw hole. And that repair would likely last the rest of the life of the vacuum. I'm all for repairing stuff the proper, "official" way....but not when you KNOW it's a problem issue that will just keep on breaking again and again. Then it's time to get creative and come up with a solution that will fix the problem permanently and last. |
Post# 464853 , Reply# 6   7/26/2023 at 21:54 (295 days old) by panasonicvac (Northern Utah)   |   | |
Post# 464857 , Reply# 7   7/27/2023 at 07:11 (294 days old) by mark40511 (Lexington, KY)   |   | |
Thanks... I'll figure out what to do...the vacuum itself is GREAT... they advertise that there are metal parts where they matter (in areas that get used a lot) I guess they didn't think that the force of gripping the handle and pushing it back/forth, turning it...isn't a critical part? LOL.. I can only imagine how this would have failed had I picked it up by the handle when moving it (which I never did)
Post# 464873 , Reply# 8   7/28/2023 at 12:24 (293 days old) by mark40511 (Lexington, KY)   |   | |
I ended up ordering the handle only...$15 w free ship... I took the handle apart. Waiting for part to get here. Only $15.
I'm assuming that part comes with all the screws, etc I need? Here's what it looks like with the handle off.
Post# 464938 , Reply# 9   7/30/2023 at 14:10 (291 days old) by repairman (Woodridge, IL)   |   | |
What's wrong with the old screws? |
Post# 465101 , Reply# 10   8/4/2023 at 15:02 (286 days old) by mark40511 (Lexington, KY)   |   | |
Post# 465102 , Reply# 11   8/4/2023 at 15:38 (286 days old) by mark40511 (Lexington, KY)   |   | |
Got the handle on...I didn't realize this was designed slightly differently...My old one had holes on both sides of the handle... this one didn't. There 2 plastic pieces that fit through the hole and went to the other side on the old one...with this one, the screws just screw in once you've got the handle together and that's it. It fits really snug and tight...
But............Get this.............. This handle didn't come with a cord wrap...I thought, no big deal.. I'll unscrew my other one and put it on this one.. only it absolutely will not fit. so now I have no cord wrap...
