Thread Number: 44736
Miele "Jazz" Dynamic U1 Upright Motor Issues |
Post# 464830 , Reply# 1   7/26/2023 at 01:34 (296 days old) by vacuumdevil (Vacuum Hell )   |   | |
Post# 464899 , Reply# 2   7/29/2023 at 03:05 (292 days old) by Tseg (World Traveller)   |   | |
I have a Jazz and after months of use my HEPA filter never looked new… always grey. But still functioning like the day I got it years later. Hopefully you resolve your issue. |
Post# 464957 , Reply# 3   7/31/2023 at 01:07 (291 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Couple of a times a month for 8 years isn't too much usage. The HEPA filter on the exhaust catches carbon dust from the motor. It is normal to be black/gray. If it's excessively blackened when it was not in the weeks prior at a rapid pace, and you don't think you dropped the vacuum or caused any damage to it, it would be worth a look to service the motor and put fresh grease/oil, check the armature and commutator, brushes, etc. A hot motor from worn out grease/oil can drag and cause more resistance which makes more heat and might translate to the hotter feel/smell to it. Make sure to check your belt as well and make sure the belt is good and not loose or slack. |
Post# 464994 , Reply# 6   8/1/2023 at 09:39 (289 days old) by FantomFan (Rochester, New York)   |   | |
