Thread Number: 44707
a project dreams |
Post# 464620   7/15/2023 at 13:53 (306 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
As you all know i love Compacts Tristar and there copy ie miricale mate ect so i had an idea.....
Tristar CS with a central vac motor or a 2 stage motor to really make it into a beast would it work ??
just a thought i had i like the style of em and id put a bigger 2 stage motor in it make it a monster vac. hahaha
One can dream ..... |
Post# 464624 , Reply# 1   7/15/2023 at 16:49 (306 days old) by vacuumdevil (Vacuum Hell )   |   | |
So a patriot might be for you. That's basically what a patriot is plus some other changes. The problem with using the TriStar body is there's not enough room to fit a central vacuum motor that would actually give it more power.
Now you could probably fit a single stage Domel motor in there. That would probably be the best option for making more power. The other struggle is the bag systems fairly restrictive. Yes you could run the HEPA Vac America bags and that would help. I'm now a little curious of the concept myself. Next time I see a TriStar with a bad motor maybe I'll set it aside for such a Frankenstein project. |
Post# 464626 , Reply# 2   7/15/2023 at 16:51 (306 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 464628 , Reply# 3   7/15/2023 at 18:09 (306 days old) by panasonicvac (Northern Utah)   |   | |
If they were to try and fit a bypass central vac motor in it, they'd need to completely redesign the tank. Those central vac motors are HUGE! But if they were to try and put a thru-flow central vac motor in it, that could maybe work since those motors are much smaller. Unfortunately I know Aerus will never do that because they quit making Tristars a few years ago (could be out of the vacuum business all together real soon). I remember former VL and YouTube user twocvbloke when he imported his Tristar CXL over to Europe from the USA, he swapped his 120 volt motor out for a 240 volt one, I'm not sure what kind of motor it was but it said that made his Tristar almost twice as powerful. That's another idea is importing over a 240 volt motor from Europe.
Post# 464630 , Reply# 4   7/15/2023 at 19:34 (306 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 464704 , Reply# 5   7/20/2023 at 15:10 (301 days old) by vacuumdevil (Vacuum Hell )   |   | |
@thevacomaticiec
I've been thinking a lot about your post. I believe this Domel motor would probably be the best option in terms of power that would actually fit inside a TriStar. Thought you'd find an interesting. CLICK HERE TO GO TO vacuumdevil's LINK |
Post# 464708 , Reply# 6   7/20/2023 at 16:29 (301 days old) by Lesinutah (Utah)   |   | |
Post# 464712 , Reply# 7   7/20/2023 at 17:12 (301 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
