Thread Number: 44470
Kirby 519 lubrication |
Post# 462696 , Reply# 1   4/28/2023 at 17:35 (384 days old) by Lesinutah (Utah)   |   | |
Isn't really lubrication points. The toe touch is a place you grease,handle spring mayor can spray there and maybe the wheel.
The motor bearing plate has a bearing you lubricate. The bottom of tge motor is a bearing you take out the armature and lube. The 516 to 562 and sanitronic 7 had the same motor and internals are all the same. You tube chicago Mike has a few videos on how to do all the bearings. |
Post# 462742 , Reply# 2   4/30/2023 at 03:38 (383 days old) by Electrolux10000 (Georgia)   |   | |
Can't find Chicago Mike anywhere on YouTube. I'm sure he's there somewhere. What I get is: Kirby enthusiast ... Do you have a link for Mike? Thanks |
Post# 462772 , Reply# 3   4/30/2023 at 21:47 (382 days old) by Lesinutah (Utah)   |   | |
There's a few videos but instead of using a bearing puller you can use a socket. The videos are awesome.
CLICK HERE TO GO TO Lesinutah's LINK |
Post# 462781 , Reply# 4   5/1/2023 at 13:28 (381 days old) by texaskirbyguy (Plano, TX)   |   | |
Be sure to use silicon oil or grease on the wheels (or any plastic parts really). Using petroleum based lube will deteriorate the plastic and the wheels will squawk even worse over time. |
Post# 462784 , Reply# 5   5/1/2023 at 15:19 (381 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
