Thread Number: 44453
Please Recommend - Time For a Bag |
Post# 462523 , Reply# 1   4/23/2023 at 14:42 (389 days old) by Lesinutah (Utah)   |   | |
CxL would need a tristar hose that is white 7 foot hose with pigtails on both sides. I'd imagine this will run about $50-$60. The power nozzles can be bought tristar/compact run $50-$75. The power nozzles on compact use a eureka power nozzle. If I'm not mistaken your power nozzle of your current rainbow is also eureka based would fit it.
If you spend about $150 a wessell werk ebk360 power nozzle is the best power nozzle made. If you get the compact/tristar with this power nozzle is going to perform better than almost any vacuum. The rainbow e series are good vacuums. You want to get a 2 speed rainbow. They come with a brushless motor which average twice the life of brushed motors. The performance is better than your current rainbow but not as good as the tristar. The upkeep is a little more than the rainbow you have now. It has a filter you clean maybe once a year. The rainbow 2 speed. Means it'san air purifier too. When you clean with the rainbow it smells and feels clean. Idk how to explain it but fresh air and seeing what you pick up is sweet. |
Post# 462531 , Reply# 2   4/23/2023 at 18:42 (389 days old) by eurekaprince (Montreal, Canada)   |   | |
Why not get a simple British Henry bagged canister from Nacecare? It’s a very durable and simple tub vac similar in shape to your Rainbow, and has a universal diameter hose handle and wands so that you could add any attachments you like from your local vacuum store. Bag changing is very simple, and it even comes with a manual cord rewind to store the cord inside the top of the canister. There are two basic sizes now, one of which is more compact. The regular size is about the capacity of your Rainbow.
These Henry’s can be ordered from Nacecare in Toronto, Canada - maybe through your local vacuum dealer. |
