Thread Number: 44426
Hoover model 300 fan blade issues |
Post# 462326 , Reply# 1   4/15/2023 at 00:47 (398 days old) by Hoover300 (Kentucky)   |   | |
Could be bearings, could be brushroll, but the main factor is for sure that fan. If you break off the blade opposite it and file them both equally, it will dampen the vibration. This is not a good solution but its a good temporary fix. You need a fan first and foremost and there is not really any viable way to fix a cast fan breakage. You'd spend more time welding, grinding, and balancing than it would be to just buy another 300 and ship it/pick it up. Maybe someone here has a spare fan for one?
Post# 462346 , Reply# 3   4/16/2023 at 01:17 (397 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Post# 462365 , Reply# 5   4/17/2023 at 03:22 (396 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Yes do not run it with the broken fan, you risk damaging the armature and stator coil. It will also sound horrible. I have a Kirby 1CR that I think has a broken fan and the whole vacuum vibrates and sounds like it's gonna explode. Did you check for the broken piece anywhere inside the bag or suction path? If you had the piece and could JB-weld it back on, it wouldnt be perfect but it would make it a little less off- balance. not sure if the jb weld would hold with that amount of velocity but i think it would. |
Post# 462387 , Reply# 6   4/18/2023 at 00:11 (395 days old) by hoover28 (Oneida N.Y.)   |   | |
I may have a extra one, contact me to remined me to look. |
