Thread Number: 44333
Two to make one |
Post# 461457 , Reply# 1   3/18/2023 at 20:29 (425 days old) by Northwesty (Renton, WA)   |   | |
Mouscapades. I kinda had a suspicion as it weighed a ton when I picked it up. #6502212 is pretty far gone.
Post# 461458 , Reply# 2   3/18/2023 at 20:31 (425 days old) by Northwesty (Renton, WA)   |   | |
I did clean it up a bit and of course the motor sounds good so I was able to get some parts. There is one on Ebay right now that could use that handle.
Post# 461465 , Reply# 4   3/19/2023 at 00:39 (425 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Good lord and I thought I had some bad ones to restore, wow wow wow, I think you set the president! Having just taken 3 dead mice out of my garage and 1 nest (so far) I can imagine how that smells.
Boiling water soak for a few minutes intervals at a time and slowly working it off going around in a circle a little bit at a time I think should get it loose. I am not sure if that rubber is heat sensitive so just test it for a bit first. That is typically what you do to old rubber tool handles as the heat makes it expand and soften a bit. I am not sure if Hoover sealed or welded those on but I don't think they would have. |
