Thread Number: 44241
How do I test a rainbow E2 black unit without any accessories? |
Post# 460549 , Reply# 1   2/22/2023 at 20:32 (449 days old) by Lesinutah (Utah)   |   | |
If you look at the pic. There is a spring loaded type safety button.
You turn the vacuum on upside down and push that spring loaded button in and tge vacuum should start it up. If you have a water basin attached will power up the machine. The bottom looks like it's in great shape. I'd bet it works. This rainbow is the best rainbow vacuum they've ever made.
Post# 460554 , Reply# 2   2/22/2023 at 21:05 (449 days old) by Lma (Westfield)   |   | |
Thank you!!! |
Post# 460847 , Reply# 3   3/1/2023 at 22:10 (442 days old) by mark40511 (Lexington, KY)   |   | |
So you have the most expensive part...(the main unit) and it looks like it's in GREAT shape...If you go to rainvac.com they have all the parts (if you wish to buy them)... But the hose, basin, dolly, PN, floor brush, crevice, dusting brush... it's gonna be expensive but probably worth it.. This model is VERY good and will last the rest of your life if taken care of...when you fill it with water, make sure to fill it about 1/2 inch ABOVE the dome...like the dome is covered and then some...
Post# 460852 , Reply# 4   3/2/2023 at 00:34 (442 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
And if you are new to water vacs, make sure you dump, rinse, and air dry the bin after using it, before putting it away like any carpet shampooer. Don't leave it with water in it. I've seen a few thrift store Rainbows that I had to leave behind because they smelled like an open sewer (left with dirty water in them for who knows how long).
