Thread Number: 44139
Dyson DC17 Project |
Post# 459665   1/22/2023 at 13:26 (480 days old) by WilliamNilliam (Michigan)   |   | |
Hello everyone! So I've recently decided to dive into the world of (older) Dyson and just picked up this DC17 on FB marketplace for $30 USD. I believe this is a Total Clean model but I'm not entirely sure since the label is gone. I do know it is a later model (seller said around 2012 ish).
Everything seems to work however there is a noted lack of suction, so after doing some reading and watching some videos I decided the best course of action would be to take the cyclone apart and boy I'm glad I did. This thing was absolutely filthy and plugged up! Interestingly this model only has the single cyclone where as every one I've seen a video on has 2, which points to this being a later model. The HEPA filter definitely needs to be changed but I'm not sure if the pre motor filter needs to be replaced or if a wash would be enough. I've also noticed that the U pipe going up to the hose doesn't make a full seal with the upper pipe, I feel like it should be on there better. So I'm going to throw the cyclone parts in the dishwasher (minus the painted top), do I run it with just water or what kind of cleaning agent should I use for this? I'm new to this but having a lot of fun learning. |
Post# 459669 , Reply# 1   1/22/2023 at 14:51 (480 days old) by panasonicvac (Northern Utah)   |   | |
Post# 459670 , Reply# 2   1/22/2023 at 14:54 (480 days old) by panasonicvac (Northern Utah)   |   | |
Post# 459671 , Reply# 3   1/22/2023 at 15:12 (480 days old) by WilliamNilliam (Michigan)   |   | |
Post# 459713 , Reply# 4   1/24/2023 at 06:18 (478 days old) by wstonehockertv (North Carolina)   |   | |
Welcome to vacuumland. And my name is also William. Coincidence, eh? |
Post# 459720 , Reply# 5   1/24/2023 at 09:43 (478 days old) by dysonman1 (the county)   |   | |
The reason that the high efficiency cyclones are clogged is that the rubber fine dust collector seal was not in place, allowing dirt to be drawn 'up'. This issue was something we dealt with a lot during the run of the '17'. Gluing the fine dust collector seal in place so it doesn't move was the solution to that problem. There's enough dirt on your Hepa filter to indicate much dirt in the fan curves. That will make the machine run loud. Removing and washing the revolving fan will correct that issue.
Post# 459726 , Reply# 6   1/24/2023 at 13:26 (478 days old) by WilliamNilliam (Michigan)   |   | |
When I first got it I did notice that the seal was getting caught on one of the tabs at the base of the bin, but otherwise its intact. I think the heat of the dishwasher helped it go back to its normal shape and doesn't get caught as easily now. I'll just make sure to be careful every time I empty it.
So continuing on, I got the cyclone washed out and back together, washed the pre-motor filter really good, and it works beautifully now! Almost a night and day difference. Tested it out in my bedroom and I'm really impressed how much it picked up. Extremely pleased with it. This thing cleaned up incredibly well. Also the upright microswitch was being very finicky so while I had the bottom open I just decided to disable it, now I have to turn the brush off manually with the button which I'm more than fine with. |
