Thread Number: 44129
Dirt Devil Plus 8 gallon wet/dry vac |
Post# 459570   1/18/2023 at 20:58 (484 days old) by panasonicvac (Northern Utah)   |   | |
I just picked this up yesterday from my local thrift store for $26. It works overall, just missing the attachments and the primary filter. It did however came with a sleeve foam filter. Needs to get cleaned up and I'll be fitting a Shop Vac dry filter for this since they don't make filters for these anymore. I'll also see if I can fit a disposable bag on this as well, I think it will work. I've been meaning to get another wet/dry vac for a while now, I'd like one that I can just use for my wood shop so I wouldn't have to haul over my other wet/dry vac. And I'm really impressed with the performance of this, it sounds just like my grandfather's Hoover Supreme 12.5 gallon wet/dry vac. I wouldn't be surprised if the motors are the same since I have yet to take this thing apart. Anyways, I wanted to share this here because I don't see many pictures or mentions about these.
Post# 459573 , Reply# 1   1/18/2023 at 22:26 (484 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 459574 , Reply# 2   1/18/2023 at 23:34 (484 days old) by panasonicvac (Northern Utah)   |   | |
A Shop Vac cartridge filter could fit but I'd need a thing to screw the filter on to make it work. It's supposed to look like this down below. And I also don't have a screw for it either. So I have no choice but to use a Shop Vac dry filter which I'd have no problem with. I'm not expected to use this to pick up wood dust by itself, I'm getting a cyclonic separator to connect with this wet/dry vac so I don't have to plug it up as much. That's what I'd recommend to use if you're picking up not only wood dust but also drywall dust and wood burning ash.
www.amazon.com/Shop-vac-9... |
Post# 459591 , Reply# 3   1/19/2023 at 17:04 (483 days old) by Blackheart (North Dakota)   |   | |
I used a shop vac branded one in it. I just cut away some of the bottom of the retainer to allow a wide washer to fit I figured it would be better to distribute the pressure. I then obtained a knob from a hardware store that fit the nut on the filter cage. As for bags you can get them on there but the inlet is rather shallow I'm not confident that it would stay on
Post# 459602 , Reply# 4   1/19/2023 at 22:15 (483 days old) by panasonicvac (Northern Utah)   |   | |
Post# 459617 , Reply# 6   1/20/2023 at 12:17 (482 days old) by panasonicvac (Northern Utah)   |   | |
Post# 459623 , Reply# 7   1/20/2023 at 15:04 (482 days old) by Blackheart (North Dakota)   |   | |
Sounds like you may not need it anymore but just in case anyone else needs it.
Post# 459639 , Reply# 8   1/20/2023 at 22:42 (482 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I am not sure if these take bags, but if you put a bag in a Shop-Vac, the filter being exposed on the bottom isn't so much to panic about. When you are doing dry pickup with no bag at all that's when you need the filter all sealed up.
Wow, now that is a strange unit. I ever knew Dirt Devil made shop vac style vacs. |
Post# 459641 , Reply# 9   1/20/2023 at 23:43 (482 days old) by panasonicvac (Northern Utah)   |   | |
On the Shop Vacs that I've used before, the bags not only plugged up real fast but also they leaked out alot of dust that the filters ended up getting clogged. So that's why I'm getting a separator for this. To prevent from not only clogging as much but also to prevent from burning the motor up as well. It's definitely nice to have extra protection for your Shop Vac so it can last longer.
Post# 466381 , Reply# 10   9/22/2023 at 19:44 (237 days old) by panasonicvac (Northern Utah)   |   | |
Post# 466394 , Reply# 12   9/23/2023 at 18:52 (236 days old) by panasonicvac (Northern Utah)   |   | |
I could've gotten something more modern for my shop or at least something that I can still get parts for. But I'm not really into wet dry vacs and I don't even expect to use this all that much so it'll probably last for the rest of my lifetime. Plus it's cool to have something that's more rare and I just couldn't let this go from the thrift store:)
Post# 466416 , Reply# 13   9/25/2023 at 00:52 (235 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
