Thread Number: 44090
Rare (?) Vintage Central Vacuum - Flo-Lite |
Post# 459496 , Reply# 2   1/15/2023 at 18:08 (487 days old) by AmtrakSebo1997 (Vacmasterthegreats basement)   |   | |
Post# 459497 , Reply# 3   1/15/2023 at 20:23 (487 days old) by Lesinutah (Utah)   |   | |
Post# 459514 , Reply# 5   1/16/2023 at 16:20 (486 days old) by panasonicvac (Northern Utah)   |   | |
The motors in Vacuflo central vacs are NOT serviceable. Especially that Flo-Lite because it is "True Cyclonic" which means that it doesn't use a bag or a filter. Dust and dirt are guaranteed to get in the motor and shorten the life anyways so what's the point of trying to service it? And you can still buy a motor for that power unit today, it's actually one of the most common central vac motors that's used in various brands and models. If the motor sounds rough, I'd just get a new motor. Or I would've also offered to upgrade it with a newer and better central vac power unit. The MD Flo-Master F650t would be my recommendation. Or the Vacuflo 566Q if that user chooses to stick with Vacuflo and something that's bagless.
builtinvacuum.com/parts/vacuflo/... builtinvacuum.com/parts/vacuflo/... builtinvacuum.com/flomaster/comp... www.vacuflo.com/wba/conte... |
Post# 459518 , Reply# 6   1/16/2023 at 20:51 (486 days old) by speedqueen (Harrison Twp MI)   |   | |
Why would a standard Lamb central vacuum motor not be serviceable? Ive taken apart tons in various equipment, even commercial extractors where they can be quite rusty. |
Post# 459520 , Reply# 7   1/16/2023 at 23:39 (486 days old) by Caligula (Wallingford, Connecticut)   |   | |
Post# 459521 , Reply# 8   1/17/2023 at 00:13 (486 days old) by panasonicvac (Northern Utah)   |   | |
Technically you can but it's not recommended for central vacs, at least that's what I've learned and experienced. As I've shared on one of the links, the motors are sealed shut. If taken apart, chances are high where the motor(s) could run unbalanced. I've once tried to service a central vac motor before when I was working at a vac shop and didn't had much success. Really the only thing that can be replaced in the motors are the brushes. And when the motor(s) go bad, why bother wasting time rebuilding it where you can just replace it alot faster and the new motor would run alot more longer?
Post# 459522 , Reply# 9   1/17/2023 at 06:40 (485 days old) by Maytag142c (Somewhere over the rainbow. )   |   | |
So... I am not sure if most of you know who you are offering advice to, but AllyDee asked a question and the person who replied with a beautiful response has more knowledge in one finger than anyone in this forum on central vacuum systems. That person happens to be Owen Perkins. He is extremely valued here and makes a living installing, servicing and replacing central vacuum systems in home, commercial and industrial environments throughout the Chicago and surrounding areas.
I have had the pleasure of meeting Owen, and for someone to question his knowledge would be a major slap in the face considering he does offer a lot here. If you have a paid subscription, I would recommend some take the time to read his material, or if you happen to like visuals, watch and listen to his youtube channel. The easiest way one could find that is by searching for vids on the Spencer central vac. Just my 2 cents for what it's worth and you might learn a few things. 🤷🏼♀️ btw... most motors in central vacs are very serviceable. |
Post# 465256 , Reply# 10   8/12/2023 at 17:34 (278 days old) by AmtrakSebo1997 (Vacmasterthegreats basement)   |   | |
To be fair, I didn't know that much about HP Vacuflo central vacs when I made that reply, and I still don't to this day. I was just trying to help. I also will take back my previous statement about vacs from the 60s usually almost always needing servicing. I mean yes, over the years it will need repairs and maintenance done to them, but if the previous owner took good care of it, the vacuum might be a bit better off. Does all of that make sense?
Post# 465257 , Reply# 11   8/12/2023 at 17:38 (278 days old) by AmtrakSebo1997 (Vacmasterthegreats basement)   |   | |
