Thread Number: 44080
New Miele C3 Improper Bag Installation / Dust Filled Bag Compartment |
Post# 459660 , Reply# 1   1/21/2023 at 19:03 (481 days old) by ralph123 (Little Rock, AR)   |   | |
Just curious, was it purchased new in a sealed box? |
Post# 459856 , Reply# 2   1/30/2023 at 07:34 (472 days old) by eurekaprince (Montreal, Canada)   |   | |
There seems to be a design flaw with the blue bag holder in the latest generation of Miele C3 canister cleaners. My friend bought a new C3 a year ago and is also having problems with dust and dirt escaping into the bag compartment. She has a tendency to open and close the bag compartment to see if the bag needs changing at the end of a cleaning session and it seems that the blue collar can slide up out of position on its own even when you don’t touch the bag collar. If you don’t slide the collar back down into the proper position, you can still close the compartment cover completely - there is no mechanism to prevent you from closing the cover if the blue bag collar is not properly in position. When you start vacuuming again, dirt and dust leaks out around the hose port and into the bag compartment. I’ve had to bring over a second vacuum to help her clean out her Miele several times in the past year.
My older Miele S8 never had this problem, so I think it must be some cheapening of the bag collar or the blue bag holder in the bag compartment. Miele should consider adding a safety mechanism whereby the motor will not turn on if the plastic collar is not all the way in the holder. |
Post# 459922 , Reply# 4   2/1/2023 at 06:11 (470 days old) by eurekaprince (Montreal, Canada)   |   | |
Still…if it is intentional, then when the bag slides up, you should not be able to close the cover until you slide it back down in place. Many people like to open the bag compartment just to check to see if the bag needs changing. They do not notice that the bag has slid out of the proper position.
If the design causes two problems to happen - either the bag collar is not seated properly or it’s too difficult to pull out, then the whole bag holder design needs to be rethought and overhauled so that the user can easily remove the bag and so that the cover can not be closed and the motor can not be turned on unless the dust bag is in its proper place. |
Post# 459989 , Reply# 5   2/2/2023 at 16:24 (469 days old) by dsmith5195 (Chicago)   |   | |
Mine same thing happened. Now it is in the shop for the 5th time period $1700 for a piece of c*** |
