Thread Number: 44037
Eureka model 2061 D |
Post# 458760 , Reply# 1   12/23/2022 at 14:43 (490 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 458761 , Reply# 2   12/23/2022 at 14:46 (490 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 458767 , Reply# 3   12/23/2022 at 16:52 (490 days old) by ecaden1 (clayton,NC)   |   | |
Cool, any idea about the fan I need? |
Post# 458769 , Reply# 4   12/23/2022 at 19:16 (490 days old) by eurekaprince (Montreal, Canada)   |   | |
Post# 458771 , Reply# 5   12/23/2022 at 20:14 (490 days old) by Lesinutah (Utah)   |   | |
Post# 458772 , Reply# 6   12/23/2022 at 20:18 (490 days old) by Kloveland (Tulsa)   |   | |
There are two fans one for the “blender motors” 5 amps or less and the pancake motor like yours. Either fan will work. But you probably want one with the taller blades so it will move more air.
CLICK HERE TO GO TO Kloveland's LINK on eBay |
Post# 458853 , Reply# 9   12/27/2022 at 12:16 (486 days old) by Paul (USA)   |   | |
P.S. I think the first 4 digits of the serial number indicate the time of manufacture as the 29th week of 1989, which would correspond with the 1986 ad. |
Post# 458867 , Reply# 10   12/27/2022 at 18:12 (486 days old) by human (Pines of Carolina)   |   | |
That's a nice Eureka. I have a very similar one, a model 2091 in hunter green and white. It's my favorite of the Eureka/Sanitaire uprights I own. Mine has the sliding 'Rugulator' height adjustment, instead of the 'Dial-a-nap' knob. I see yours in an "ESP" model. Does it have the two-speed switch? If running it on high is too much, try running it on low. Also, try adjusting the height upward a click or two to see if that makes a difference.
Post# 458916 , Reply# 11   12/28/2022 at 17:59 (485 days old) by ecaden1 (clayton,NC)   |   | |
No, it is a single speed model, it has the cheap seeming push button foot switch. I do much prefer a switch on the handle. |
Post# 458970 , Reply# 14   12/30/2022 at 09:12 (483 days old) by Paul (USA)   |   | |
Good to know, Owen; thanks. |
Post# 458971 , Reply# 15   12/30/2022 at 10:05 (483 days old) by eurekaprince (Montreal, Canada)   |   | |
I remember trying to clean a deep plush carpet with a black Eureka Boss 1934 upright with a 6.5 amp motor. I could not find an appropriate setting for the Dial-a-Nap height adjuster. The motor was just too strong and if you set the Dial a Nap too low, you could feel the suction lock and the brush roll stop. If you set it too high, the brush roll would skim the surface.
I think this is why the newer Eureka Ultra uprights replaced the height adjustment Rugulator with a sliding suction relief valve. If you set the suction to “ESP” it was at full power with the vent completely closed. If you slid the adjuster to lower the suction on the carpet, it worked fine for deep plush carpets. Higher power motors (more than 4 amps) really require a way of bleeding off the suction at the nozzle in order to clean deep plush carpets. |
Post# 459178 , Reply# 17   1/5/2023 at 10:17 (477 days old) by joevacman1 (Valley Stream New york 11581)   |   | |
