Thread Number: 43814
Need to reach the ceiling and washable filter.. Henry? |
[Down to Last] | ![]() |
Post# 457207 , Reply# 1   10/3/2022 at 06:31 by mark40511 (Lexington, KY)   |   | |
OR....
you could get whatever vacuum you want and just buy this to go with it...which is what I did. As long as the vacuum cleaner has a hose...connect this to it and you can clean all over the place...I have to use a cheap adapter for it to fit my hose...I also like that the hose is light weight...I've had it 4 years now..no issues with the holes or tools and I use it all the time. CLICK HERE TO GO TO mark40511's LINK |
Post# 457218 , Reply# 2   10/3/2022 at 17:07 by Blackheart (North Dakota)   |   | |
You should look at sidewinder Tools I feel like they would be a good match for your purpose. The standard wands for them are like 6' and I know they make some higher reach kits too If you're looking to attach a domestic vacuum you'll want to get the 1.25" wand/nozzles. The 8" brush should be a good choice .
As for the vacuum Henry is a powerful option there is also the Numatic James which uses the same motor with slightly less capacity and has a more basic cord halo rather than the manual winder, but comes at a lower price. You should use bags in them though. They're huge and pretty cheap. Also not using bags in them shortens the motor warranty. |
Post# 457257 , Reply# 3   10/5/2022 at 18:03 by Blackheart (North Dakota)   |   | |
Post# 457306 , Reply# 4   10/7/2022 at 18:54 by huskyvacs (Gnaw Bone, Indiana)   |   | |
How tall is your ceiling height? A Henry with a few wand kits and a straight (not angled) dusting brush from any vacuum that will fit the wands would work.
This advertisement photo is for a Shop-Vac wand set
