Thread Number: 43391
kirby 500 series fan removal |
Post# 453300   6/3/2022 at 22:19 (692 days old) by vacuser (milford,ohio)   |   | |
what is the trick & safe way to keep the motor from turning when you change the fan ?
Post# 453302 , Reply# 1   6/3/2022 at 22:46 (692 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Dwayne,
What you need to use to keep the armature from turning as you get the impeller fan off would be to use a special fan lock tool that Kirby supplies to its network of authorized service centers. Otherwise, you can use an ice pick. Regardless, make sure you insert it in the right place to prevent damage to the armature as you get the fan off. For extremely rusty fans, you may want to use some WD-40 and let it cure before you get down to removing it. ~Ben |
Post# 453370 , Reply# 2   6/5/2022 at 17:20 (690 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 453382 , Reply# 3   6/5/2022 at 19:22 (690 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 453469 , Reply# 4   6/7/2022 at 14:29 (688 days old) by vacuser (milford,ohio)   |   | |
