Thread Number: 43325
Hoover Dimension 1000 and Dimension Supreme |
Post# 452687   5/17/2022 at 07:52 (709 days old) by ts1520 (derby)   |   | |
I'm looking for a powerhead for my hoover dimension 1000. There's a Head for a dimension supreme for sale on ebay. I'm wondering if that would fit. Thanks! |
Post# 454202 , Reply# 1   6/29/2022 at 00:21 (667 days old) by Durango159 (State College, PA)   |   | |
Did you find one yet?
Usually you can search eBay for Hoover Quadraflex Powermatic and find one. Any Hoover power nozzle with pig tail cord and raised button wand lock will fit that machine. Granted it can depend what model Hoover Dimension you have. Does your machine have a gas pump handle or standard? The gas pump hoses used a T Shape plug adaper. Some with 2 prongs and others with 3 depending on the model. The ones with 3 prongs, simply split the headlight off from connection with the brush roll. They did that so that for certain models with a gas pump hose, you could turn off the brush roll switch and headlight stayed on. The original Quadraflex PowerMatic for Dimension 1000 canisters had a foot pedal for brush roll control and that foot pedal left the headlight staying on as well so many Dimensions had the 2 prong, T shaped plug Regardless, you can rewire any power nozzle with a T shaped plug to a flat 2 prong if it doesn't fit your hose Once rewired, any Windtunnel, PowerMax power nozzle you find would work as well Here are some photos of what to look for. |
