Thread Number: 43289
Clean Obsessed bags in TriStar - YAY! |
[Down to Last] | ![]() |
Post# 452334 , Reply# 1   5/5/2022 at 11:19 (279 days old) by dysonman1 (the county)   |   | |
![]() 2
Post# 452336 , Reply# 3   5/5/2022 at 12:52 (279 days old) by dysonman1 (the county)   |   | |
![]() 2
You'll never have to worry about dust throwing off the balance on the VM3 motor if you use the HEPA bags. I use the Perfect V.A.C. bags in every machine they make the bags for. You can't believe the difference the cloth HEPA bags make to the old Eureka and Sanitaire machines. Clean Obsessed bags are identical but for the packaging.
Post# 452352 , Reply# 5   5/5/2022 at 21:40 (279 days old) by Thevacomaticiec ![]() |
Post# 452364 , Reply# 7   5/6/2022 at 09:16 (278 days old) by Dysonman1 (the county)   |   | |
![]() 2
Post# 452368 , Reply# 8   5/6/2022 at 14:53 (278 days old) by Thevacomaticiec ![]() |
Post# 452411 , Reply# 10   5/7/2022 at 20:37 (277 days old) by Thevacomaticiec ![]() |
Post# 452934 , Reply# 12   5/23/2022 at 22:23 (261 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Matthew, I have a Patriot as well, much agreed, the angle of the bag makes it tricky to get the bag out without spilling dirt when you open the bag door. Try tipping the vacuum back BEFORE opening the bag door, that will make the dirt piled up at the front of the bag sit at the back of the bag when you open it up. I was getting tired of the paper bags for the TriStar, Miracle Mate and my Patriot, so I modified all of them to use generic Kenmore C/Q or Miele GN HEPA Cloth bags bought cheaply from AliExpress. All I had to do with the Patriot was remove the tube from the bag door, then wrap the metal tube on the door the rubber tube mounts on with tape to increase the diameter so the bag fits snug. Then take a pair of scissors and cut the arrows and clip off the bottom of the Miele bag collar before putting it on. With the Miracle Mate, you simply have to save a cardboard bag top to use with the bag so it seals properly. Now all 3 have sealed HEPA Cloth bags with excellent filtration :).
Antoine, the V.A.C. HEPA Cloth bags are not on Amazon.ca, only Amazon.com in America, so who knows if they will ship here, and you would pay a small fortune if they did. Buy a pack of generic Kenmore C/Q HEPA Cloth bags, remove the cardboard collar, cut the bag open at the front, then line the cloth bag with it, put it in and close the bag door. Used to do that and works well, seals up nicely. Rob |
Post# 452954 , Reply# 13   5/24/2022 at 09:30 (260 days old) by dysonman1 (the county)   |   | |
![]() 1
Post# 452969 , Reply# 14   5/24/2022 at 17:36 (260 days old) by Thevacomaticiec ![]() |
Post# 452971 , Reply# 15   5/24/2022 at 18:43 (260 days old) by countryguy ![]() |
![]() 1
I use the closed Hepa bags in my Patriot....eliminates any mess when removing the bag.
Gary
Post# 452979 , Reply# 16   5/24/2022 at 20:49 (260 days old) by Blackheart (North Dakota)   |   | |
I had a problem finding them. I tried searching for clean obsessed which was pages of misc stuff, tried vacuum america clean, and vac36 "item code" and wasn't finding them. The are there I cannot remember what I used to finally find them but man what a pain. I've still got 2 of the hepas left but I wanted that free shipping since I had one other item I had to order.
I tried those closed top bags for patriot but just....wasn't feeling it with them. I like the closed top concept it's much cleaner but dislike that they're still paper. I've seen the C/Q conversion method but that wouldn't work for the Tristar DXL at least without modding it. Anyways here's a link to the bags for those still seeking them. CLICK HERE TO GO TO Blackheart's LINK |
Post# 453062 , Reply# 17   5/26/2022 at 23:12 (258 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Devin and Gary - I totally agree, the closed top Patriot bags should be made of HEPA Cloth material, would be mess free to empty and provide excellent pre-motor filtration. The closed top bag should also be made STANDARD equipment, not optional, discontinue the Stormy Bag, and distribute the closed top bag thru distributors to sell in vac shops since Patriot dealers aren't common like other DTD dealers are.
Devin - The way I used the Kenmore C/Q HEPA Cloth bag in the Patriot and TriStar in the past was to take the cloth bag out, take the Kenmore bag, cut it open at the front, take off the cardboard collar, stuff it into the cloth bag, wrap the excess over the metal rim and rubber seal, put it back in and close the bag door. Seals up perfectly inside the vacuum with no need for a cardboard collar. I grew tired of the open bag though, so I converted the TriStar with a plastic extension wand from a Bissell PowerForce and a brass plumbing piece from the hardware store. Just stick it into the bag door with the hose inserted and put the bag onto it. To make the seal, I made a cardboard collar for it. I also used another Bissell PowerForce tube to convert the Patriot, TriStar and Miracle Mate to use the Electrolux Guardian HEPA filter. Huge cheapskate here....NOT spending $200 plus shipping and taxes for the Patriot Medik Aire HEPA filter when the Electrolux filter is under $50 on Ebay. I will have to make a post soon detailing how to do these conversions. Rob PS - Devin, where was this you have seen the C/Q bag conversion method before? I would be interested to see how others have done it. |
Post# 453087 , Reply# 18   5/27/2022 at 20:39 (257 days old) by Blackheart (North Dakota)   |   | |
