Thread Number: 42038
Hoover Celebrity filter idea |
Post# 443386   6/27/2021 at 07:09 (1,033 days old) by fan-of-fans (USA)   |   | |
Lately I’ve been thinking of ideas for making a replacement filter for the Hoover Celebrities that use the sleeve style filter. Vacuum shops I believe suggest the foam filter from a Bissell Powerforce bagless.
I had also heard of using a Shop Vac filter. So I picked up a foam sleeve for a wet/dry vac. I measured the height of the intake vents which is just over 2” or so, then I cut a strip from the filter. It works out that you can get exactly 3 Celebrity filters from one sleeve with no waste! I cut notches to go over the “hump” at the back of the cover. It fit, but a bit loosely. Then I had an idea. I got my pack of electrostatic vent filters. These I got at Home Depot several years ago. I made some exhaust filters from these for my Hoover Slimline. I cut one filter into two long strips. Lay it inside the foam filter. It was the exact width of the foam. Then I cut the length of both pieces slightly to fit and cut the “notch” again for the “hump”. I think my invention looks great, almost factory. Now the filter seals to the housing, and now You get electrostatically charged allergen filtration. It looks very similar to the pre motor filter in modern bagged canisters and clean air uprights. Foam on bag side electrostatic on motor side. My only concern is will it be too thick? I think the foam itself is about the thickness of the original. I’ll have to try it out and see. I don’t have a suction meter or Kill A Watt though. The photo with the Stuffed bag shows the original filter for reference. |
Post# 443399 , Reply# 1   6/27/2021 at 13:15 (1,033 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
Post# 443411 , Reply# 2   6/27/2021 at 21:00 (1,033 days old) by rugsucker (Elizabethton TN)   |   | |
Should work great and be BETTER than original.With age genuine original filters can turn to dust even in the factory packaging. |
Post# 443429 , Reply# 3   6/28/2021 at 13:27 (1,032 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 443471 , Reply# 4   6/30/2021 at 00:06 (1,030 days old) by cam2s (Nebraska)   |   | |
I wrapped a silver king flat disk around the center post for some extra filtration. One could trim it up a bit more and secure it with a rubber band if you wanted to look cleaner.
Post# 443472 , Reply# 5   6/30/2021 at 00:34 (1,030 days old) by tolivac (Greenville,NC)   |   | |
Not just Celebrity-I use the SK filter discs is my central vacuums-just place it over the foam filter in the vacuum under the bag.These filters are useful in OTHER vacuums besides SK. |
Post# 443562 , Reply# 6   7/2/2021 at 23:20 (1,027 days old) by fan-of-fans (USA)   |   | |
Agreed, the filter material in these is almost always long gone. This cleaner actually had the filter still intact, but when I went to remove the old bag, the filter just crumbled.
have used the Frost King or Duck window AC foam to make a new diffuser for the bottom of the Celebrity. I think it would work well for a motor filter combined with the white material, as it's a bit thinner than the shop vac type filter I used. The Silver King filter is a good idea too. I wouldn't have thought of that. Yes, it seems many vacuum filters can be replaced with even better than original ones with a little ingenuity. |
