Thread Number: 41495
Canister Deep Cleaner |
Post# 439736   3/13/2021 at 12:05 (1,140 days old) by mark40511 (Lexington, KY)   |   | |
I came across this youtube video of someone pushing this for car detailing. There are tons of videos of people using it for car detailing, but it can be used for carpet cleaning too. It comes with a longer hose as well.
Here's the thing: This is just MY opinion: I feel like canister deep cleaners are better at extracting water (not necessarily better, otherwise) simply because you can push the head into the carpet. This is my biggest complaint with upright deep cleaners...ESPECIALLY on low pile carpet. I would much rather use this to clean my carpets than an upright. Canister deep cleaners are almost impossible to find. I know there is Henry Wash.. CLICK HERE TO GO TO mark40511's LINK |
Post# 439744 , Reply# 1   3/13/2021 at 17:03 (1,139 days old) by Blackheart (North Dakota)   |   | |
Yeah for certain types of carpets and areas wand machines are more convenient. If you'd be cleaning carpet something with a higher PSI pump would be better choice I think I've read somewhere that wand machines should have between like 200-500 psi of course that machine is geared towards upholstery cleaning
Post# 439760 , Reply# 3   3/14/2021 at 09:21 (1,139 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
It seems the canister extractors are mainly used for car detailing now rather than residental carpet cleaning, here's a video comparing two extractors, I really like the motor sound on the more expensive one, I'm not sure if these could be adapted to clean larger areas. Mike CLICK HERE TO GO TO n0oxy's LINK |
Post# 439761 , Reply# 4   3/14/2021 at 09:33 (1,139 days old) by fan-of-fans (USA)   |   | |
Household canister style carpet/upholstery cleaners seemed to fall out of popularity in the US after upright machines became popular in the 90s onward.
Outside of the United States they seem more common. Although I think Vax has Bissell's did have one last canister carpet cleaning machine and wet/dry vacuum called the Big Green Complete up to a couple years ago. But it's since been discontinued. I think they also sold one of the older Big Green style machines under the Rubbermaid commercial brand, but that's been 10 years ago already. |
Post# 439762 , Reply# 5   3/14/2021 at 09:57 (1,139 days old) by n0oxy (Saint Louis Missouri, United States)   |   | |
This is the only canister extractor I found that actually includes a wand, not sure how good it is but it's designed for commercial use. Mike CLICK HERE TO GO TO n0oxy's LINK |
Post# 439765 , Reply# 7   3/14/2021 at 10:39 (1,139 days old) by gregvacs28 (U.S.)   |   | |
If one would pair something like a Hoover Spinscrub upholstery tool with the Cleanmore or a wet dry vacuum and something like a little green Machine to dispense fluid You'd have a good pair.
Post# 439766 , Reply# 8   3/14/2021 at 11:14 (1,139 days old) by fan-of-fans (USA)   |   | |
Post# 439772 , Reply# 10   3/14/2021 at 13:30 (1,139 days old) by fan-of-fans (USA)   |   | |
Post# 439780 , Reply# 12   3/14/2021 at 13:48 (1,139 days old) by mark40511 (Lexington, KY)   |   | |
OK so.......the spot cleaners are essentially miniature canister cleaners for small areas. When I have to clean up occasional stains or cat puke...I have never used the solution tank...I just put a little carpet cleaner in a cup of hot water and pour over/ extract, rinse, rinse, extract. I don't think pushing more weight down is a false sense simply because the spot I cleaned and saturated HEAVILY dries much much faster than if I had used an upright (on my berber)
My rainbow Aquamate (I used it recently) I notice when the water tank is FULL it extracts more water because of the weight of the water. As the tank empties, the aquamate gets lighter and seems to extract LESS because of less weight. I have this odd shaped 10lb hand weight that I just placed on top of the aquamate and surprisingly it stayed there without fall off because of its shape...I think I'm extracting 30% more water with the weight than without it. |
