Thread Number: 41282
Numatic George wiring help |
Post# 437816 , Reply# 1   1/27/2021 at 06:50 (1,184 days old) by compuvac ( )   |   | |
This might help its the wiring schematic from the manual.
Post# 437859 , Reply# 2   1/27/2021 at 21:58 (1,184 days old) by Lesinutah (Utah)   |   | |
Two lines off a motor and pump are positive and negative. Positive is black negative/neutral white.
Black, red blue are usually power or positive. If you have for example two blue wires. One will have a white line down the wire. The one with the white line would be neutral and the other would be the power. |
Post# 437873 , Reply# 3   1/28/2021 at 04:23 (1,184 days old) by compuvac ( )   |   | |
In Europe we use brown for live and blue for neutral.
I think the wires that go to from the switch to the motor are usually white on Numatics Positive and negative are terms for direct current (DC). George runs on alternating current (AC). So it doesn't really matter if you connect a brown cable to blue one as long as you don't create a short circuit and follow the schematic you should be fine. |
Post# 437878 , Reply# 5   1/28/2021 at 06:07 (1,183 days old) by compuvac ( )   |   | |
Post# 437925 , Reply# 6   1/28/2021 at 22:31 (1,183 days old) by Lesinutah (Utah)   |   | |
