Thread Number: 40907
Royal 606 armature |
Post# 434490 , Reply# 1   11/2/2020 at 15:30 (1,270 days old) by Lesinutah (Utah)   |   | |
Post# 434491 , Reply# 2   11/2/2020 at 15:32 (1,270 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 434493 , Reply# 3   11/2/2020 at 16:20 (1,270 days old) by Gj9696 (Prosper)   |   | |
Misaligned bearings? That means I have to replace the armature or bearings? I've never repaired a royal vac before. |
Post# 434496 , Reply# 4   11/2/2020 at 16:33 (1,270 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Post# 434500 , Reply# 5   11/2/2020 at 22:59 (1,269 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 434501 , Reply# 6   11/3/2020 at 00:26 (1,269 days old) by Gj9696 (Prosper)   |   | |
Madman, it still moves when I pull the pulley. After I put all the parts back in place. It might need a new armature. |
Post# 434502 , Reply# 7   11/3/2020 at 00:28 (1,269 days old) by Gj9696 (Prosper)   |   | |
I'll take a look see tomorrow.👍 |
Post# 434505 , Reply# 8   11/3/2020 at 07:12 (1,269 days old) by Lesinutah (Utah)   |   | |
Post# 434534 , Reply# 9   11/3/2020 at 21:53 (1,268 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 434536 , Reply# 10   11/3/2020 at 22:16 (1,268 days old) by Lesinutah (Utah)   |   | |
Post# 434555 , Reply# 11   11/4/2020 at 11:00 (1,268 days old) by Gj9696 (Prosper)   |   | |
I took apart the motor a bit more and played with it and put it back in place. The fan is not scraping and dinging now.😁😉👍 So I can now use attachments! If it has any problems again I'll give y'all a shout-out. Thank y'all. |
Post# 434560 , Reply# 12   11/4/2020 at 13:51 (1,268 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Gabriel,
What exactly did you do that ultimately solved this problem (for now, at least)? I mean, as you dug deeper into the motor assembly, what else had you found that had caused this problem? I would like to think those two videos helped you. ~Ben This post was last edited 11/04/2020 at 16:08 |
Post# 434572 , Reply# 13   11/4/2020 at 17:00 (1,268 days old) by Gj9696 (Prosper)   |   | |
Kirbyclassiciii, the videos you sent me did helped. I did went a little deep by taking apart the rest of the motor and put everything back in place. |
Post# 434576 , Reply# 14   11/4/2020 at 19:47 (1,267 days old) by Lesinutah (Utah)   |   | |
The vacuum off pull the fan towards the front of the vacuum. If it doesn't slide your good. Remember what I said about the spacers. The spacers in my opinion are usually the only thing that would cause play in the fan.
Take pics of everything. I have tore apart about 20 royals and it's the details. Kirby's 505 d80 pretty similar setup. The classics are similar and heritages are similar. The g series is all similar. The Kirby's have parts diagrams. Royal has Ben and Jeff. There's no parts diagrams. In summary pictures and make sure fan isn't loose. Les |
Post# 434635 , Reply# 15   11/6/2020 at 04:59 (1,266 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
Vacuums get thrown and banged around outside of a collector's care. It probably was dropped or fell and the motor got jostled out of true. Taking the entire motor apart and then reassembling from the ground up probably re-seated a part you didn't notice was out of place.
I had a cheap China pride floor fan that I got out of the dump once and the motor kept sliding out of the armature unless I kept it leaned forward. I did a redneck fix on it by using some old washers as spacers to wedge the fan blade forward to keep the motor aligned. The pedestal and pole itself was bent all over so I guess it fell over a lot or got run over. Made a good air circulator for the shed anyway. |
