Thread Number: 40684
Electrolux XXX motor problem |
Post# 432300   9/22/2020 at 16:29 (1,311 days old) by johnnyb59c (13240 n 3980 rd dewey oklahoma)   |   | |
well this is lovely. the reason I had it apart in the first place. the motor shifts when I turned it on and made this sound like you're holding a hose against your hand and makes that noise as you slowly move it away for a second. I thought it was the bag not sealing as I first turn it on. I took the exhaust plate off and I can see the motor shift when I turn it on. the mounting nuts seem tight and the rubber seal couldnt possibly be more soft. wish I could post videos on here to show.
Post# 432343 , Reply# 1   9/23/2020 at 10:52 (1,310 days old) by johnnyb59c (13240 n 3980 rd dewey oklahoma)   |   | |
Post# 432386 , Reply# 2   9/23/2020 at 21:50 (1,309 days old) by Lesinutah (Utah)   |   | |
It can ruin things. Take the motor out.
Here is two suggestions. 3m makes a thick double side adhesive mounting tape. I used it to mount window covers on my car. The other is get insulation for automobile and put it inside where the motor sits. It's a small problem now but it will eventually ruin things. |
Post# 432387 , Reply# 3   9/23/2020 at 21:53 (1,309 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
NO NO NO
the mounting ring is done for replace it take the motor half appart and put a new ruber ring thts the only reason electrolux motor move no Le that will never work i have 3 electrolux canister thats the only reason those motor move his mounting ring is kaput and has a tear time for a new one . |
Post# 432390 , Reply# 4   9/23/2020 at 21:58 (1,309 days old) by Thevacomaticiec (Bathurst New Brunswick Canada )   |   | |
This is the rubber ring yall need
Post# 432416 , Reply# 6   9/24/2020 at 09:18 (1,309 days old) by dysonman1 (the county)   |   | |
Post# 432425 , Reply# 7   9/24/2020 at 14:19 (1,309 days old) by johnnyb59c (13240 n 3980 rd dewey oklahoma)   |   | |
I hope this holds- the 3 little "shock absorbers" I call them, one had come separated from the metal plate. I used some crazy glue and reinstalled the motor and seems perfect now
Post# 432433 , Reply# 8   9/24/2020 at 14:32 (1,309 days old) by dysonman1 (the county)   |   | |
Post# 432436 , Reply# 9   9/24/2020 at 14:42 (1,309 days old) by johnnyb59c (13240 n 3980 rd dewey oklahoma)   |   | |
Post# 432455 , Reply# 12   9/24/2020 at 18:29 (1,309 days old) by johnnyb59c (13240 n 3980 rd dewey oklahoma)   |   | |
before I stored it away in the shed a couple of years ago after the mishap I think the companion was still with it. I dug the old machine out and brought it back to the house and lucky me I have an original cord stowed away. the motor sounded real nice and quiet until I heard the vibrating sound of the motor against the inside wall of the vacuum. only reason I quit using it is because the machine end plug on the cordwinder blew a few sparks and blew a breaker.
