Thread Number: 40430
Simplicity Synchrony with a bad roller? |
Post# 429244 , Reply# 1   7/29/2020 at 21:42 (1,366 days old) by Lesinutah (Utah)   |   | |
Post# 429250 , Reply# 2   7/30/2020 at 09:03 (1,366 days old) by dysonman1 (the county)   |   | |
Post# 429254 , Reply# 3   7/30/2020 at 10:06 (1,366 days old) by Blackheart (North Dakota)   |   | |
Les, this is a synchrony the tandem air machine with two motors there is no clutch assembly on them I think you're thinking the symmetry which are a single motor clean air machine.
Tom probably has this right though typically when you encounter vibrations it's going to be the fan in the direct air motor though if you have found that the bearings are having issues it definitely doesn't hurt to replace them while you have it apart. You may be tempted to try to run the machine while the brushroll is out to isolate the issue but due to the hall sensor that little wheel that touches the belt as it runs it will shut off the lower motor very soon after it's started because when that little wheel is not turning the machine is going to assume that the brushroll has jammed so it will activate the shut-off for the direct air meant to protect the belt. So I would first start with those brush roll bearings since you already have identified them as a problem most simplicity dealers or riccar dealers should have them on hand. Just be sure you're getting the right sized ones as machines like the symmetry used a larger size bearing the ones in the synchrony and the synergy brushrolls are smaller in size |
