Thread Number: 40077
Silverado hose help |
Post# 425436 , Reply# 5   5/14/2020 at 10:32 (1,443 days old) by suckolux (Yuba City, CA)   |   | |
Post# 425442 , Reply# 7   5/14/2020 at 11:50 (1,443 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Jon's case holds water...those were indestructible cleaners. I would second getting the genuine replacement hose, Aerus still sells them.
Take the gray cover off the bag door (4 screws inside), turn the dirt selector all the way up, and remove the knob with number and adjust it one setting number accordingly, or "clock" it so the number will match the setting. |
Post# 425444 , Reply# 9   5/14/2020 at 11:58 (1,443 days old) by gregvacs28 (U.S.)   |   | |
The hose that would be a good match is: It's even the same color.
Post# 425445 , Reply# 10   5/14/2020 at 11:59 (1,443 days old) by gregvacs28 (U.S.)   |   | |
which is similar to what you have now. |
Post# 425446 , Reply# 11   5/14/2020 at 12:08 (1,443 days old) by gregvacs28 (U.S.)   |   | |
Electrolux Sidekick? It didn't come out until about 1986, but you can certainly use it with the Silverado. Perfect for upholstery, carpeted stairs, and cleaning your car. I love it. CLICK HERE TO GO TO gregvacs28's LINK |
Post# 425447 , Reply# 12   5/14/2020 at 12:16 (1,443 days old) by gregvacs28 (U.S.)   |   | |
Attachments? We see you've go the dusting brush. What about the crevice tool and bare floor brush with wand set?
Post# 425458 , Reply# 14   5/14/2020 at 14:21 (1,442 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 425463 , Reply# 17   5/14/2020 at 15:51 (1,442 days old) by gregvacs28 (U.S.)   |   | |
I converted my Sidekick for use with my Central Vacuum with the addition of a special adapter.
Post# 425464 , Reply# 18   5/14/2020 at 15:52 (1,442 days old) by gregvacs28 (U.S.)   |   | |
Here's the floor tool with original aluminum wands. They also made some chrome wands and plastic sets. Either will work.
Post# 425476 , Reply# 20   5/14/2020 at 21:16 (1,442 days old) by JustJunque (Western MA)   |   | |
I know you're responding to Joshua, to help with his replacement hose and attachments needs.
But, I just have to tell you; your explanation was so informative and interesting! And I don't usually read lengthy posts unless it's something that I'm needing help with. Among my Electrolux/Aerus collection, I have an Ambassador III, which I keep set up pretty much exactly as you were describing. You've inspired me to pull that machine out tomorrow for the day's vacuuming. Barry |
Post# 425482 , Reply# 22   5/14/2020 at 21:42 (1,442 days old) by Jo (Dallas,TX)   |   | |
Here is a deal on a sidekick that will work for you. Not a bad price. CLICK HERE TO GO TO Jo's LINK on eBay |
Post# 425483 , Reply# 23   5/14/2020 at 21:45 (1,442 days old) by Jo (Dallas,TX)   |   | |
Here are some attachments not a bad price either but an auction. CLICK HERE TO GO TO Jo's LINK on eBay |
Post# 425486 , Reply# 24   5/14/2020 at 22:19 (1,442 days old) by radiowonderland (New York)   |   | |
The auction items look really good--except maybe the brush, does it look worn, uneven? |
Post# 425487 , Reply# 25   5/14/2020 at 22:36 (1,442 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 425501 , Reply# 26   5/15/2020 at 07:57 (1,442 days old) by human (Pines of Carolina)   |   | |
I've got a couple of the generic hoses like the one in reply no. 9 and the only real problem I've had with them is the screw closest to where the handle attaches to the wand has a tendency to work itself loose. The easy solution is to replace it with a self-threading screw the same length but with slightly wider threads to get a better bite into the plastic. I've had to fix that problem on two of mine.
The SideKick is a must-have item and is readily available on eBay for less than $20. Honestly, there's no reason not to get one. These machines really do last a lifetime. I have two 1205s that are more than 50 years old and both are still going strong. The reason I've zeroed in on Electrolux and Kirby as my vacuum cleaners of choice is they're durable almost to the point of indestructibility and designed to be repaired. It's a feature missing in damn near everything these days. |
Post# 425511 , Reply# 28   5/15/2020 at 11:57 (1,442 days old) by radiowonderland (New York)   |   | |
I'm bidding on that set of attachments! |
Post# 425567 , Reply# 32   5/16/2020 at 21:25 (1,440 days old) by human (Pines of Carolina)   |   | |
Radiowonderland wrote:
I'm a little sad about not shopping local, but this seems best. I reply: I get that but you are supporting an independent business, just in a different community, which is almost as good, considering that independent Electrolux dealers are a bit of a dying breed. The one in my city shut down several years ago and the closest one is about 40 miles away. At any rate, I'm glad you found a good hose. That will keep your Silverado gig fo years, if not decades, to come. Jon wrote: I’ve seen the generic rubber [hoses] start to rip through there, haven’t seen a genuine one do it yet... I reply: I own one. Ironically, it came to me with my Silverado. The handle was totally trashed and there's a one-inch tear in the hose just south of the handle. I sealed it over with RTV silicone and if and when I find a replacement handle, we'll see how well it lasts. Someone on here suggested sealing it with Flex Tape. I may give that a try if the silicone doesn't hold. I have enough other hoses that repairing that one hasn't exactly been a priority. |
Post# 425571 , Reply# 33   5/16/2020 at 22:24 (1,440 days old) by suckolux (Yuba City, CA)   |   | |
That famous dusting brush, I loaned a old Panasonic upright to the kids for some time, I had included an aqua flipper elux dusting brush in its tools,they wouldn't give the brush back! No way Jose! On another note, being silly I promise! My brother commented about having me creamated one day! I said just suck me up with the old suckolux! No mess,no fuss! He replied do you really think that sucker will still be working? My response oh hell yeah
Post# 425581 , Reply# 34   5/16/2020 at 23:06 (1,440 days old) by gregvacs28 (U.S.)   |   | |
David, do I dare ask how a conversation devolves to the point of a sibling threatening to cremate you? lol |
Post# 425583 , Reply# 35   5/16/2020 at 23:16 (1,440 days old) by suckolux (Yuba City, CA)   |   | |
Post# 425634 , Reply# 39   5/17/2020 at 19:56 (1,439 days old) by Compactelectra (Palm Springs)   |   | |
This thread caused me to get out two of the Lux round dusting brushes. The one on the right is the XXX dusting brush which I have always loved. Indestructible. The one one the left is plastic with the white dusting bristles. The interesting thing about that one is that it is in the Silverado colors which meant they made it all the way up to the 80s. Now I’ll have to use them.
Post# 425658 , Reply# 40   5/18/2020 at 07:46 (1,439 days old) by ridgidwd0670 (se wood co ohio)   |   | |
Post# 425689 , Reply# 41   5/18/2020 at 20:39 (1,438 days old) by Jo (Dallas,TX)   |   | |
To change the bristles you have to pry gently from the outside with a flat screwdriver to release the metal ring that hold the bristles in from the clamps in the bottom of the head |
Post# 426028 , Reply# 42   5/25/2020 at 19:29 (1,431 days old) by gregvacs28 (U.S.)   |   | |
Received my new Electrolux hose. Unpacking. |
Post# 426066 , Reply# 43   5/26/2020 at 08:46 (1,431 days old) by human (Pines of Carolina)   |   | |
It's definitely a third-party hose, given that the handle has a power switch and a sliding suction control but that's not necessarily a bad thing. It should give you many years of good service. I actually like having a power switch on the hose and wonder why Electrolux/Aerus never included one. It's very convenient to be able to instantly shut off the power nozzle without bending down to hit the switch on the vacuum or on the power nozzle itself, if it is so equipped.
One small maintenance note: You should periodically check and tighten the screws on the underside of the handle. They have a tendency to work themselves loose, especially the one forward of the switch. This happens to both of my generic hoses that have pistol grips. I have a third one with a little straighter handle design that, while not as comfortable to use, does not exhibit this tendency. Enjoy your new toy! |
Post# 426071 , Reply# 44   5/26/2020 at 12:25 (1,431 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 426094 , Reply# 51   5/27/2020 at 08:46 (1,430 days old) by luxlife (Under a Pecan Tree)   |   | |
These don't seem to be as easy to come by, even through the supply houses. I've been looking for a while for a replacement to my ZB89 canister. |
Post# 426336 , Reply# 54   5/31/2020 at 12:44 (1,426 days old) by human (Pines of Carolina)   |   | |
Jon wrote:
He just came in for some help and glad we could get him going, but one never knows, he might check in again. I reply: I would count myself in that group. I first found this site in December 2013 after I rescued a Kirby G6 from beside a dumpster and needed/wanted a little information about it. Once I found the information I was after, I checked out for a couple of years until I scored a Royal Prince 501 handheld at a thrift store for $2 and change. After that, the sickness set in; my fleet has grown from three or four machines to 24 and I've never left. |
Post# 426420 , Reply# 59   6/3/2020 at 00:29 (1,423 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
