Thread Number: 39149
Hoover model 150 bearing housing assembly |
Post# 415344   10/27/2019 at 07:39 (1,643 days old) by 2011hoover700 (owosso michigan)   |   | |
Hi I'm hoping either someone has a Hoover model 150 bearing and housing or knows a way to repair mine as in the picture it got cracked.
Thanks.
Post# 415347 , Reply# 1   10/27/2019 at 10:33 (1,643 days old) by Lesinutah (Utah)   |   | |
Post# 415354 , Reply# 2   10/27/2019 at 15:09 (1,643 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 415359 , Reply# 3   10/27/2019 at 16:58 (1,642 days old) by 2011hoover700 (owosso michigan)   |   | |
Here's another view it's a plastic housing with metal bearing. I am currently trying loctite 60 second universal glue.
Thanks. |
Post# 415363 , Reply# 4   10/27/2019 at 19:19 (1,642 days old) by Lesinutah (Utah)   |   | |
E7000 is what you need. On my 913 I thought housing came apart. I grabbed my grinder and cut bottom of the bearings. I'll be damned the red hot metal started itself a fire with the 50 year old grease.
The 7000 can cause cancer and make you sterile or even go blind. It is my go to as it adheres almost any two surfaces together. I did crack a small piece of the carbon brush housing on 913. I used e7000 and it still holding strong. Les |
Post# 415366 , Reply# 5   10/27/2019 at 21:12 (1,642 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 415423 , Reply# 6   10/31/2019 at 06:29 (1,639 days old) by 2011hoover700 (owosso michigan)   |   | |
Post# 415435 , Reply# 7   10/31/2019 at 16:44 (1,638 days old) by Lesinutah (Utah)   |   | |
Post# 415438 , Reply# 8   10/31/2019 at 21:37 (1,638 days old) by MadMan (Chicago, IL, USA)   |   | |
I suppose if a loose washer was in there, it might have been thrown by the motor spinning. Unlikely, though. What it does look like is the armature was pressed too far back up into that housing. Either something hit the end of the shaft, or there were too many thrust washers on the armature and it cracked the housing when someone tightened the screws down. Is that what you meant?
Post# 415454 , Reply# 9   11/1/2019 at 13:38 (1,638 days old) by 2011hoover700 (owosso michigan)   |   | |
@madman a loose washer if I'm not mistaken was inside and I suspect that it got thrown by the motor as when I dismantled it I found it like dropped into the casting, but maybe it jammed the armature and it flew into the bearing housing but I repaired it with the loctite 60 second universal glue and it actually started working even better than when I had it the last 8 months ever since.
Thanks for all your input. |
