Thread Number: 38235
Miracle mate accessories |
Post# 407063 , Reply# 1   3/22/2019 at 20:50 (1,861 days old) by compactc9guy (Bathurst NB)   |   | |
Go on ebay and look under miracle mate or tristar vacuum since they use the same hose and handle .
CLICK HERE TO GO TO compactc9guy's LINK on eBay |
Post# 407071 , Reply# 2   3/22/2019 at 23:46 (1,861 days old) by shenny (Minnesota )   |   | |
Replying to whether the Lindhaus power head M 30 was direct connect and the seller said yes it is direct. Does anyone know if it’s compatible with the Magic Mate? Other parts still needed are hose,wand and swivel handel. Thanks |
Post# 407080 , Reply# 3   3/23/2019 at 04:41 (1,861 days old) by Blackheart (North Dakota)   |   | |
Ah. The M30 appears to have come off an upright and wouldn't be compatible with the setup you're going towards as it should have a 35mm European connection where you'd need a 32mm or 1.25" connection. Then there's the electrical issue. The prong setup doesn't have a direct conversion to a pigtail to my knowledge.
You could replace the neck with a pigtail neck to make it work but the neck alone appears to run about $68 I'd just seek out another head one that already has a pigtail (external cord) already built onto it. |
