Thread Number: 37993
2012 Sentria - What do I need to be careful about? |
Post# 404896   2/1/2019 at 06:33 (1,910 days old) by got2bjennyg (Brunswick, Ohio, USA)   |   | |
I'm going to look at a Sentria 1 built in 2012 that is for sale locally. Other than the obvious things that a person would look at when buying a used item, is there anything in particular I should be concerned about?
If the vacuum is in decent cosmetic condition and appears to operate normally, is $125 a reasonable amount to pay for it? It includes the original box, attachment set and shampoo system (I will probably never use the shampoo system since I have a Bissell big green upright extractor). Thanks in advance for your guidance. |
Post# 404911 , Reply# 2   2/1/2019 at 14:40 (1,910 days old) by got2bjennyg (Brunswick, Ohio, USA)   |   | |
Post# 404947 , Reply# 3   2/2/2019 at 03:44 (1,909 days old) by huskyvacs (Gnaw Bone, Indiana)   |   | |
I got my Sentria for $40 on eBay, but that was a once in a lifetime fluke deal. I would recommend going to pawn shops and seeing what they have for sale as far as Kirbys. Kirbys for whatever reason are a heavily pawned vacuum, and I believe some pawn shops will let you make monthly/weekly payments on it. Unless you really love the Sentria, you should see if they have any Avalirs in there for that price range, those are very nice looking.
Post# 404950 , Reply# 4   2/2/2019 at 06:11 (1,909 days old) by got2bjennyg (Brunswick, Ohio, USA)   |   | |
There is a Sentria for $50 about 30 miles away. I drove out there, took one look at the neighborhood and house and left. Some deals just aren't worth it LOL.
I'm headed out this am to look at these. It's a retired guy hat says he's worked on hundreds of Kirby's. His price is very fair IMHO. $200 for the Sentria II and $250 for the Avalir (no shampoo system).
Post# 404964 , Reply# 5   2/2/2019 at 13:54 (1,909 days old) by got2bjennyg (Brunswick, Ohio, USA)   |   | |
Post# 404969 , Reply# 6   2/2/2019 at 15:16 (1,909 days old) by got2bjennyg (Brunswick, Ohio, USA)   |   | |
So excited. Lol
Post# 404985 , Reply# 7   2/2/2019 at 21:26 (1,908 days old) by MadMan (Chicago, IL, USA)   |   | |
Post# 405059 , Reply# 8   2/4/2019 at 11:52 (1,907 days old) by vacuumdevil (Vacuum Hell )   |   | |
I would check the self propel Dr leaver. Dump out the mini emptier in front of them and inspect the fan with a flashlight.
Then use that as part of the negotiation 🙂 As a preemptive measure I personally would just change the brush roller and start fresh. And also doesn't hurt to launder the outer vacuum Here's a playlist of Kirby maintenance videos on such. Good luck ! CLICK HERE TO GO TO vacuumdevil's LINK |
Post# 405315 , Reply# 9   2/9/2019 at 22:52 (1,901 days old) by broomvac (N/A)   |   | |
After reading your original post but before reading your fourth, I was going to advise you to keep an eye out for tech drive issues. More commonly than they wear out, tech drive systems can be knocked out of adjustment. One symptom of this is that the vacuum will propel itself more readily in one direction than the other. Almost always, the cure is an adjustment of the attachment point between the handle pivot and the slide block underneath. It wouldn’t cost you anything to do it yourself, but it would be a pain.
I digress. The great thing is, you already picked one which drives well. 👍 Thanks for sharing! |
