Thread Number: 37185
Rainbow D4C SE |
Post# 397088 , Reply# 1   8/21/2018 at 21:30 (2,074 days old) by suckolux (Yuba City, CA)   |   | |
Post# 398604 , Reply# 2   9/22/2018 at 15:34 (2,043 days old) by timborow (Georgia)   |   | |
Does anyone have anymore suggestions about what could be causing this noise? Does the separator need replacing? |
Post# 398785 , Reply# 3   9/26/2018 at 08:34 (2,039 days old) by dysonman1 (the county)   |   | |
Try running the machine without the separator on a dry water pan. The separator or the fans are imbalanced. The fans might have enough dirt in them, or the separator is warped (it can happen). Either way, running without the separator will tell you. If the vibration goes away, it's the separator. If the vibration is still there, it's the fans in need of a clean (and grease the three bearings while you're doing that).
Post# 398825 , Reply# 4   9/26/2018 at 21:29 (2,038 days old) by MadMan (Chicago, IL, USA)   |   | |
I'm with dysonman1, it sounds like a vibration, rather than the fan hitting something. You'll notice on spin-down, the sound appears very strong at one particular speed of rotation, then falls off greatly at other speeds. It's likely hitting its resonance frequency there. Broken or extremely dirty blades would be my guess.
While you have it apart, though, check the thrust play in the motor. |
Post# 398865 , Reply# 6   9/28/2018 at 01:10 (2,037 days old) by Rivstg1 (colorado springs)   |   | |
after reading your original post, I pulled out my D4SE to listen to it ( and use the opportunity to change my Separator at the same time). No sound, but enjoying cleaning with it anyway( I had just taken it apart for the first time to clean and inspect/remove carbon from Communicator..... the whole thing seemed like a low 'hour' machine based on the condition!)
