Thread Number: 36099
Best device to clean hair from upholstry |
Post# 387101 , Reply# 2   3/3/2018 at 15:48 (2,245 days old) by blackheart (North Dakota)   |   | |
Looking at not a machine but rather a vacuum tool. The Simplicity Pet hair beware or Riccar fur get it tool. They are like a self cleaning lint brush they work very very well for removing hair. The prices on Simplicity's website are higher than in store. This will work with a 1.25" vacuum connection.
CLICK HERE TO GO TO blackheart's LINK |
Post# 387103 , Reply# 3   3/3/2018 at 16:28 (2,245 days old) by crazykirbydude (Lexington, KY)   |   | |
The Aerus Little Lux is a great performer. Nothing can stop the brush, and the suction power is enormous. It's kind of pricey at $90, but it is corded and will las you many years.
Post# 387114 , Reply# 4   3/3/2018 at 17:26 (2,245 days old) by Lesinutah (Utah)   |   | |
Post# 387135 , Reply# 5   3/3/2018 at 19:36 (2,245 days old) by eurekaprince (Montreal, Canada)   |   | |
You should try the Eureka Easy Clean 71B. It’s pretty good on upholstery and has an on-board hose with a crevice tool to get into tight spaces. It also has a convenient way of wrapping the 23-foot cord.
See link below.... CLICK HERE TO GO TO eurekaprince's LINK |
Post# 387161 , Reply# 6   3/3/2018 at 22:40 (2,245 days old) by fan-of-fans (USA)   |   | |
Post# 387164 , Reply# 7   3/3/2018 at 23:22 (2,245 days old) by Lesinutah (Utah)   |   | |
4
Not a big Fan of the eureka that clogs way too easy. If we are talking handheld. The purple riccar would be nice. My wife has shark hand vacuum it's very powerful. We also have the new dirt devil hand vac and it's as powerful as shark with better brush agitation. Riccar or dirt devil are imo best hand vacs.
Post# 387167 , Reply# 8   3/4/2018 at 00:46 (2,245 days old) by tolivac (Greenville,NC)   |   | |
Just look for another DD Ultra hand vac-you see them show up at some vac shops.for getting hair and such from furniture these machines are better then the new hand vacs.Or look around for a Royal Prince hand vac from a thrift place. |
Post# 387173 , Reply# 9   3/4/2018 at 07:38 (2,245 days old) by Luxkid1980 (Richmond, Virginia)   |   | |
I agree with fan-of-fans. The Electrolux sidekick is great. I use it to clean cat hair from blankets and furniture. Powered tools are nice to have. Which full size machines do you currently use? |
Post# 387192 , Reply# 11   3/4/2018 at 11:41 (2,244 days old) by human (Pines of Carolina)   |   | |
Post# 387205 , Reply# 12   3/4/2018 at 14:59 (2,244 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
First of all, I would not assume your Dirt Devil hand vac is dead. Those hand vacs in particular use a Ametek universal powerhead motor used by many brands, such as Filter Queen, TriStar & Eureka, to name a few. There is a good possibility that the motor may just need new carbon brushes. I would strongly suggest opening up your Dirt Devil & taking apart the motor. If the brushes are connected by a spring & wire to the field coils in the motor, then it's truly gone, no way you can replace those. BUT, if it is a older motor like I suspect where the brushes just have a spring attached & not the wire as well, you can order new carbon brushes, install them yourself, re-assemble & you're back in business.
As for the my fellow members suggestions about the Riccar & Simplicity hand vacuums, I would avoid them, as well as any modern bagless hand vac that has a HEPA filter in the cup. Those filters, especially small ones like these use, are a real pain in the butt to clean! Plus, you WILL eventually have to buy replacements, & more frequently than you may think. For the hassle of cleaning the filter & replacement costs, I cannot recommend them. If you do decide to buy a replacement hand vacuum, I would agree with their suggestions in looking at local thrift shops & online craigslist ads to try & find a couple of older hand vacs with cloth bags to use, such as the Dirt Devil, Royal, Black & Decker, etc. Much easier to clean out & deal with on a regular basis, especially for someone like you cleaning multiple homes & very busy. But, if you're willing to spend the $90 & buy new, Crazykirbydude's suggestion, the Aerus Little Lux hand vacuum, would be well worth the money spent & would be your best choice. A proven design that has been around since the mid 90's with only styling changes, the internals have not changed. Cloth bag would be easy to empty out & live with, plus it also has a geared permanent belt. The cost for the Simplicity & Riccar hand vacuums should be just as much, or more, than this, & won't be nearly as convenient for you to clean out the filter & live with day to day. However, I would NOT suggest getting the Aerus Sidekick or Wessel Werk HEB160. Both these electric mini powerheads will work, BUT ultimately, any rotating brush you WILL have to cut the hair off the brushroll, & I have found you spend just as much time vacuuming the hair off as you do having to cut hair out of the brushroll. The Wessel Werk, in particular, is a really bad choice, as the brushroll openings on it are quite small, & their powerheads especially are more difficult than most to take apart yourself at home & clean out. For that reason alone, I cannot recommend ANY Wessel Werk powerhead. Plus, with the brushroll opening being smaller than most, you will find it more tedious & frustrating getting in there with small scissors & twezzers. The only way I suggest a solution with a rotating brush is if you want a hand vacuum not attached to a normal upright or canister. The Simplicity Fur Get It & Riccar Pet Hair Beware tool, as suggested by Blackheart, does work. But, it has a quirky design with some limitations & is better suited to upholstery than carpet, which means it's ineffective on stairs. For the money they want for that tool, I don't think it's worth it. Your REAL SOLUTION here is to get a dedicated pet hair upholstery tool that DOES NOT use a rotating brush, such as the one I have linked to below. I own this particular tool, & I find it works quite well. This is a old, proven design that has been made by various manufacturers since the 1980's. Simple, effective, & it WORKS! All you do is pull the tool back, it traps the hair on the felt pad, then push it forward & the hair slips off the and & is pulled in by the vacuum's suction. At the end, you will need to give the felt pad a quick swipe with the hose, but that's a minor thing really. It comes with a ring that you tighten down onto the hose, & loosen to take off, which means it can fit regular hoses or European size hoses, like Miele & Sebo vacuums. Replacement pads are available, & it's not that expensive at all, so this might be worth looking into, & it seems to fit what you need it for. Rob Carbon brushes: www.goodvac.com/Rainbow_D4_SE_noz... Pet hair tool: www.dustdeal.com/shopBrowser.phpQ... |
Post# 387230 , Reply# 14   3/4/2018 at 18:18 (2,244 days old) by Lesinutah (Utah)   |   | |
I really don't mean to be rude but no older prince or that eureka will work well. The prince bag system clogs too easy not heavy on power either. The eureka is worse the head gets clogged with normal use doing pet hair. I really dislike eureka. I had a choice between it and a 501 prince. Prince all day. Riccar Dd and shark are far and when I say far I mean there on freeway others can't drive on freeway.
Dirt devil brush falls off occasionally and riccar not best bagging but the eureka is not worth plastic it's made of. Just my 2 cents but I have a great disdain for eureka. Led |
Post# 387275 , Reply# 15   3/5/2018 at 11:44 (2,243 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
Patrick - Yes, I do have experience with these type of HEPA filters. Not from using a Simplicity or Riccar hand vacuum, but from using a Shark stick vacuum a few times that had a small HEPA filter with a screen over it, just like this one. My experience has been that with these small HEPA filters, not all of the dirt just taps out, you usually have to take a brush of some sort to clean between the pleats of the filter, & wash & rinse it every few uses. Even then, you're looking at replacing it every 6 to 12 months. $14.95 may not seem like much to you, but it IS to me, considering a hand vacuum is being used for only small surfaces & stairs. If this was a HEPA filter in the dirtcup of a full sized upright or canister, that I wouldn't mind paying that much for, considering it's a full sized filter going into a full sized vacuum cleaning everything.
I stand by my original post stating these small HEPA filters in handvacs are a pain in the butt, & you're better off finding a older model that uses a cloth bag. Rob |
Post# 387283 , Reply# 17   3/5/2018 at 15:39 (2,243 days old) by kloveland (Tulsa)   |   | |
Post# 387481 , Reply# 21   3/7/2018 at 22:58 (2,241 days old) by kirbylux77 (London, Ontario, Canada)   |   | |
I'm glad I was able to be of help to you! :-)
Yes, I would say that wire you found broken would be the direct cause of your handvac failing. I highly doubt that is something that you could easily repair yourself. I would save the brushes, & perhaps the bag & brushroll, in case you find another Dirt Devil handvac to use for a good price. Please do report back on how the pet tool I suggested works out for you. I own it myself & have been VERY pleased with it's performance. And hey, there's nothing wrong with using a Shark as your main vacuum, just as long as you maintain it & you like it :-). Rob |
