Thread Number: 20832
Motor Speed when Belt Drive Equated For |
Post# 233228   5/19/2013 at 13:23 (3,994 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
Has anyone ever tried to figure out the belt drive ratio on any vacuum cleaner that uses such a configuration? The belt drive ratio between motor shaft and brush roll will play a part in the final RPM which will lower the actual motor speed (that is, before brush engagement).
You need to figure out: *The diameter of the motor shaft *The diameter of the belt *Motor speed before belt drive equation ~Ben |
Post# 233232 , Reply# 1   5/19/2013 at 13:41 (3,994 days old) by KirbyClassicIII (Milwaukie, Oregon)   |   | |
