Well I took apart the Lux AF today only to find a deep groove carved into the commutator this was caused by misaligned brushes.Well that's how it goes sometimes, I will most likely run into more of these motors so I decided to store the body and restore this treasure at a later date.
Post# 91138 , Reply# 1   2/9/2010 at 18:58 (5,189 days old) by kirbykid63(Wilmington Delaware)
OK I think I have a solution If I use A 1205 bearing plate and Armature and spacer this will fit the AF motor.All I have to do is get longer studs with washers to hold the bearing plate down to the motor frame. I have used 1205 armatures before in the model G's and they work just fine.
