Thread Number: 5305
I need help on my sanitaire |
Post# 59092   1/25/2009 at 18:29 (5,581 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Hi all I took of the springs under the machine,the top is loose but it is hanging up on the dial a nap nob. How do I remove this nob to free the top piece. Thanks Mike for the help so far. Richard Groski |
Post# 59105 , Reply# 1   1/25/2009 at 19:06 (5,581 days old) by vintageroyal611 ()   |   | |
Just remove the star shaped screw in the center of the knob and the hood will come right off |
Post# 59106 , Reply# 2   1/25/2009 at 19:10 (5,581 days old) by swingette ()   |   | |
you should use a "torx" key/bit. there are more torx screws under the hood. |
Post# 59108 , Reply# 3   1/25/2009 at 19:23 (5,581 days old) by kirbykid63 (Wilmington Delaware)   |   | |
Ok It worked,the screw was so filled with dirt I did not know it was a torx screw. Now is the bottom bearing replaceable? and what is the correct fan to order from Hesco? Thanks For the help Richard Groski |
Post# 59112 , Reply# 4   1/25/2009 at 19:46 (5,581 days old) by swingette ()   |   | |
Ive been using the nylon "Durafan". Its supposed to be more shatter-resistant than the standard Lexan. #77247355n Lexan #12988 These are for the double ball-bearing, pancake (heavy duty) motors. |
