Thread Number: 5123
Is my Kirby Sentria not cleaning right? |
Post# 57244 , Reply# 1   12/30/2008 at 12:26 (5,607 days old) by tommymilan (milano)   |   | |
Hello, to use the kirby carpet shampooer as a "pile lifter" you have to disassemble the carpet shampooer , place the plastic shield-adaptor and then insert the shampooer's brushroll WHITHOUT the tray: the adaptor is in the carpet shampooer's box. Only this way those debris and things can be picked up; If you think your kirby is not working fine at carpet cleaning my advice is to replace the standard stiff bristles brushroll with medium stiffness brushroll (the one that was previously standard) and it will work great but it's always important to adjust the brushroll at the proper height (I mean inside the powernozzle) and make sure that when the kirby is operating you hear the vibration and air passing through the powernozzle and that no heavy marks remain on the carpet when you pull the cleaner backwards. I hope this helps! tommy |
