Thread Number: 4993
My Latest Kirby Project. |
Post# 55673   12/4/2008 at 12:12 (5,622 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 55674 , Reply# 1   12/4/2008 at 12:13 (5,622 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 55675 , Reply# 2   12/4/2008 at 12:14 (5,622 days old) by kirbymodel2c (Nottingham, England)   |   | |
Post# 55676 , Reply# 3   12/4/2008 at 12:50 (5,622 days old) by lux1521 ()   |   | |
Its a model 2R, I think. If not a 2R it must be a 3R. Nice one. |
Post# 57190 , Reply# 5   12/29/2008 at 12:26 (5,597 days old) by kirbymodel2c (Nottingham, England)   |   | |
Hi, In order to get in to it your best taking your best taken off the main handle,bag/emtor and main head. Take off the front wheels by taking off the wheel axle and metal front that holds the safty switch. Once they have been removed unscrew the screws on the fan case and remove it carefully. It might be stiff to remove but becareful not to crack the fan chamber. Once fan chanber removed you can use a lockin pin to lock the armature by inserting it through the air vent. It locks in to a hole in the armature by the cooling fan. Once its locked you can unscrew the fan. Once the fan is off you can unscrew the 4 screws under it. Take the carbon bushes out by unscrewing the black srews at the other end of the motor unit. Once the carbons are out you can take the plate behind the fan off to reveal the armature. You should be able to inspect the motor then. Hope this helps. Ebay is a good source for parts or a kirby service centre. But older C/R series are harder to get than the 505 and newier models. Hope it goes ok. Let me know how things go. James |
