Thread Number: 3853
Heltp with polishing kirby!!!! |
Post# 43816 , Reply# 1   6/15/2008 at 08:44 (5,793 days old) by filterqueen83 ()   |   | |
Brasso and steel wool and it comes fairly clean quicker than mothers. |
Post# 43819 , Reply# 3   6/15/2008 at 11:26 (5,793 days old) by clarkecombi ()   |   | |
Wont the sand pape scratch the metal? |
Post# 43840 , Reply# 6   6/15/2008 at 15:43 (5,793 days old) by clarkecombi ()   |   | |
Ok Ill give it a try...What kinda Cloth do u use for Polishing and would one of those things that mothers makes that goes on the end of a power drill to polish with be good. |
Post# 43978 , Reply# 9   6/16/2008 at 17:38 (5,792 days old) by clarkecombi ()   |   | |
Well im going for the Highly Burn your eyes out shine........Someone sqaid mothers chrome cleaner.....does that work in the old kirbys or only on the new ones. |
Post# 43984 , Reply# 11   6/16/2008 at 18:38 (5,792 days old) by camelotshadow (Valley Village)   |   | |
tried 0000 with mothers have 600 wet dry sand paper there's polishing then there's polishing What do you have to do to get that mirror like shine? Guess that's were power polishers can come in use as I have to be careful with this as I might be getting a carpel tunel thing |
Post# 44025 , Reply# 12   6/16/2008 at 23:48 (5,792 days old) by clarkecombi ()   |   | |
Well i tried it and the Rug nozzle turned out good,but the dang power plant has still got them spots...how long are u supposed to rub that polish in and Is there any trick or tool u can use to scrub it in real good |
Post# 44332 , Reply# 15   6/19/2008 at 22:15 (5,789 days old) by camelotshadow (Valley Village)   |   | |
Never use oven cleaner on alum Its really a reactive metal likely to clous up on you I thought about jewelers rouge probably red, green & white I might have to look into that |
Post# 44357 , Reply# 17   6/20/2008 at 00:32 (5,789 days old) by clarkecombi ()   |   | |
Oh I tried the Wet Sanding with 800 grit and it totaly dulled the Finish on my rug nozzle. I tried buffing it out but it stays Dull...Oh well it does have that retro Brushed aluminum look that is pretty cool. |
Post# 44362 , Reply# 18   6/20/2008 at 00:55 (5,789 days old) by vacuumkid3 ()   |   | |
Well, buy some 1500 grit and 2000 grit...that should do it! You just have to work your way up, I suppose! I bet it'll work...that way you shouldn't have those spots anymore! ~~K~~ |
Post# 44365 , Reply# 20   6/20/2008 at 01:06 (5,789 days old) by camelotshadow (Valley Village)   |   | |
sodium hydroxide is lye It is used in soaps & then neutralized Can't see using it for aluminum even of you wipe it off real fast. I've used oven cleaner inside the oven sometimes it comes in contact w alum trim & it turns white & cloudy |
Post# 44366 , Reply# 21   6/20/2008 at 01:13 (5,789 days old) by camelotshadow (Valley Village)   |   | |
That guy has great stuff & his prices are reasonable. Didn't see the kit before |
Post# 44382 , Reply# 22   6/20/2008 at 10:30 (5,788 days old) by louvac (A)   |   | |
Does anyone have an extra Kirby Classic (1st brown machine) hose for sale? |
Post# 44565 , Reply# 23   6/22/2008 at 03:14 (5,787 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
Post# 44566 , Reply# 24   6/22/2008 at 03:18 (5,787 days old) by gottahaveahoove (Pittston, Pennsylvania, 18640)   |   | |
