Thread Number: 37008  /  Tag: 80s/90s Vacuum Cleaners
Can anyone help? Can't get Simplicity 7250 replacement pedal installed correctly.
Post# 395554   7/25/2018 at 15:18 (2,101 days old) by RamJacCorp (Philly)
I bought a replacement pedal for my stalwart vac (have done all my own repair work so far), and attempted to install it. Cannot get the spring to provide enough tension for the pedal to work properly. Contacted Simplicity, but all they would say is that their techs used to use a "special jig" to install it. Has anyone figured out how to do this job, or do I have to just give up and take it in for service?
Post# 395559 , Reply# 1   7/25/2018 at 16:45 (2,101 days old) by RamJacCorp (Philly)
Problem solved!
Well, thanks to a photo someone else had included in an old post here, I was able to spot the problem, and get the spring seated correctly. The wheel is a bit snugger than it should be, so it doesn't spin very freely, but the darned pedal works again, so I'm happy.
