Thread Number: 36798
This is what a new Fantom Thunder might have looked like. |
Post# 393719   6/22/2018 at 22:23 (2,134 days old) by broomvac (N/A)   |   | |
Hi vacuum fans,
A while back I posted about some new old stock Fantom parts I procured. I bought a brushroll, a crevice tool, a dusting brush, a chassis, a filter housing, and a dirt tank. I was shocked that there was still an unused Fantom Thunder dirt tank out there and that I was the collector to stumble upon it. What luck! Anyhow, a month or so ago I had an opportunity to install all of these new parts on my 1999 Thunder. With all these new parts I can get an idea of what this thing might have looked like when it was new. There is one final improvement in store for this machine. I will be replacing the spindle-side motor bearing because I noticed that the original 19 year old bearing started to sound a bit rough. My new carpet seems to load up the brush/belt more than before and it seems that was a bit much for that nearly 20 year old grease to handle. I'll likely do a "Broomvac's Guide to Bearings" thread in the next couple of months and will use my Fantom as an example. The Lamb Ametek motor in this vacuum will make a great example because its bearings are easy to replace. Questions and comments welcome. |
Post# 393722 , Reply# 1   6/22/2018 at 22:54 (2,134 days old) by fan-of-fans (USA)   |   | |
