Thread Number: 36383
Hoover 1030 Brushroll??? |
Post# 390087 , Reply# 1   4/7/2018 at 20:02 (2,209 days old) by vacuumlad1650 (Wauponsee, IL)   |   | |
Post# 390098 , Reply# 2   4/7/2018 at 22:29 (2,209 days old) by broomvac (N/A)   |   | |
Your vibration issue is likely due to a bent brush roll body. In other words, the whole thing has been bowed over time by being stored with a belt pulling on it. You can check for a bowed brush roll body by installing the roller without a belt attached and spinning it by hand with the machine unplugged. Look at the gap between the center of the brush roll and the bottom plate as you spin the brush roller. If you see this gap changing as the brush roll wobbles around, you will need a whole new brush roll body. Bearings alone will not solve your problem.
If the bearings are in fact your issue, you can replace them Thankfully, there are still plenty around. Frequently, though, I do not replace the bearings. I simply clean them out and refill them with high-temperature synthetic grease. My convertible had a bent brush roll. I found another brush roll which was not bowed but was rusty. I took all the rust off with a wire wheel and repainted it. The thread below details what I did. CLICK HERE TO GO TO broomvac's LINK |
