Thread Number: 36022
Kirby Trim Removal & Instillation Help ? |
Post# 386382 , Reply# 1   2/19/2018 at 12:28 (2,257 days old) by Lesinutah (Utah)   |   | |
Post# 386384 , Reply# 2   2/19/2018 at 12:37 (2,257 days old) by Lesinutah (Utah)   |   | |
Post# 386385 , Reply# 3   2/19/2018 at 12:52 (2,257 days old) by jpsbgt (Oregon )   |   | |
Yes Les I do need revits ! I do have a gun but unsure if I can gain access to the underside of nozzle ? |
Post# 386386 , Reply# 4   2/19/2018 at 12:59 (2,257 days old) by Lesinutah (Utah)   |   | |
Post# 386387 , Reply# 5   2/19/2018 at 13:06 (2,257 days old) by Lesinutah (Utah)   |   | |
Do you have screws for the wheels and a spring for toe touch.
Post# 386392 , Reply# 6   2/19/2018 at 17:19 (2,257 days old) by eurekastar (Amarillo, Texas)   |   | |
4
The trim can be stretched onto the existing rivets. Heat the trim up under some hot water to make it pliable. Take a very small flat head screwdriver and insert it through the hole on the trim. Next, brace the end of the screwdriver between the rivet and the headlight and slide the trim down the screwdriver and onto the rivet, using the screwdriver as a guide. Use the screwdriver to help fit the trim hole around the rivet.
