Thread Number: 36013
Kent KT-300 shop vac |
Post# 386311 , Reply# 1   2/17/2018 at 21:54 (2,259 days old) by MadMan (Chicago, IL, USA)   |   | |
They sell generic shop vac hoses by diameter, you should be able to find them at the hardware store. However, you may have to finagle something for the connection to the machine. Seems like a special end piece. You may be able to reuse the original one with a new hose, or jam the end of a new hose into it. Not sure.
CLICK HERE TO GO TO MadMan's LINK |
Post# 386316 , Reply# 2   2/18/2018 at 01:05 (2,259 days old) by electrolux137 (Los Angeles)   |   | |
~ If I'm seeing it correctly, the machine-end connector was very cleverly designed. The screw-down pin on the suction outlet would fit into the channel around the hose connector; if it's not screwed down too tightly, just tight enough to hold the hose in place, the hose would have a swivel function -- something very few shop-vacs have.
I agree with others that it would be easy to find replacement hose onto which the original ends can be attached. They probably just screw onto the hose. There might be some glue that might be a bit of a challenge to free up. Try soaking the ends of the hose in a bucket of hot water for a few minutes.
Good luck! |
Post# 386398 , Reply# 5   2/19/2018 at 18:10 (2,257 days old) by compactc9guy (Bathurst NB)   |   | |
Post# 386407 , Reply# 6   2/19/2018 at 20:55 (2,257 days old) by snakes5 (United States)   |   | |
Not yet, but I was headed in the direction of using industrial hose. |
Post# 386438 , Reply# 7   2/20/2018 at 08:53 (2,257 days old) by kirbyvertibles (Independence, KS)   |   | |
Post# 386905 , Reply# 9   2/28/2018 at 08:18 (2,249 days old) by kirby519 (Wisconsin)   |   | |
Contact a company in your area that services Janitorial equipment. They can get you hoses and cuffs. If you pay with cash or credit card they will more than likely work with you. |
Post# 386945 , Reply# 10   2/28/2018 at 21:58 (2,248 days old) by Lesinutah (Utah)   |   | |
