Thread Number: 35804  /  Tag: Recipes, Cooking Accessories
HOME-MADE NUT BUTTER
Post# 384303   1/15/2018 at 13:51 (2,292 days old) by electrolux137 (Los Angeles)
Last night I had a hankering for some crackers with peanut butter. Alas, we were all out of peanut butter. So ... what to do ...
Well, we did have a can of Spanish peanuts ... I wondered if I could make some peanut butter myself.
I sat down and googled "home made peanut butter." That search yielded a gazillion hits of course. I looked at the top dozen or so; the one thing that all had in common was that you need a powerful blender. We have a 1960s Oster Galaxie blender with a Pro Blender 6-Point Blade. I thought that ought to do the trick.
One recipe suggested lightly toasting the peanuts first. The warmth will help release the oils and make the butter smoother, and will also make a more robust flavor.
So I dumped the can of Spanish peanuts onto a small baking tray and warmed them up in the toaster oven. Then I poured them into the blender and let it go on full power.
After the nuts were pulverized -- about two minutes -- I drizzed in about two teaspoons of peanut oil and about a half-teaspoon of coconut palm sugar.
I let it go another 3-4 minutes, then poured it into a small Mason jar. Per all the recipes on Google, I let it chill in the fridge for a couple of hours because it was warm and runny.
Well I Decliah! The peanut butter is delicious and creamy smooth. I was afraid the skins might make it bitter or tough but that's not the case at all.
For the next batch, I'm going to a bag of deluxe mixed nuts -- brazil nuts, cashews, almonds, pecans and hazelnuts (with the hazelnuts removed because I don't like 'em).
Post# 384332 , Reply# 1   1/16/2018 at 02:15 (2,292 days old) by tolivac (Greenville,NC)
Been making "homemade" peanut butter for some time now-Used the "Carfolina Nut" flavored peanuts-and these make DELICIOUS peanut butter-so easy-just put the nuts in my SS VitaMix blender jar use the tamper a couple times to get the nuts crushed-then let it run for a minute--all it needs-then pour the butter into a mason jar for about a weeks worth.When I run out-just repeat what I did before.What kind of blender are you using-peanut butter making is pretty tought job for a blender-curning those nuts takes A LOT of power.Can burn out lesser blender motors!!!Blentec and VitaMix hold up well for this job.If you don't have a blender use a Cusinart or similar food processor-just takes longer but will do the same thing.Food processor-pulse several times to chop and crush the nuts-then let the processor machine run until the mixture is liquefied.For the blender or processor-the blades rupture the peanut cells freeing the oil.
Post# 384345 , Reply# 2   1/16/2018 at 13:21 (2,291 days old) by Kirbysthebest (Midwest)
Looks yummy.
